Old 07-29-2012, 04:31 PM   #1
swood67
7 ft garage door
I have just bought my first 72 K5 blazer and would like to install 35's and 4 inch suspension lift. Can anyone tell me if I will have any trouble getting this under a 7 ft garage door?
swood67 is offline   Reply With Quote
Old 07-29-2012, 04:43 PM   #2
Firebirdjones
Re: 7 ft garage door
It might squeeze in providing you have a garage door opener that pulls the door ALL the way up.
Mine is stock lift with 33" tires and it measure right at 73-74" to the roof. That gives you about 10" of wiggle room. It'll be close.
Alot of variables. Lifts aren't always exactly as advertised, and actual tire height varies between manufactures, even how the floor is poored might affect it as you pull in.
Firebirdjones is offline   Reply With Quote
Old 07-29-2012, 06:36 PM   #3
AJs72K5
AJs72K5's Avatar
I've got 35's with a six inch lift. Height is 6' 11.5" at the top of the roll bar. No hard top on mine.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 07-29-2012, 09:18 PM   #4
My3Sons!
My3Sons!'s Avatar
I have 35s with 7 inch lift, and barely make it with no top. You should be good for sure with no top. Might be sketchy with the top on. One thing to watch for is the arm your door motor attaches to the door(where the quick disconnect lever is) it usually is lower than the 7 foot clearance.
My3Sons! is offline   Reply With Quote
Old 07-29-2012, 09:23 PM   #5
mud.man.rj
mud.man.rj's Avatar
Not sure, I have a 9ft door because all my buddy's have at least 38" tires and 7" of lift. Should make it, but close. Most 35" tires are actually just over a 33" when on the truck with the weight of the truck on them.
mud.man.rj is offline   Reply With Quote
Old 07-30-2012, 10:19 AM   #6
swood67
Thank you, Sounds like it wont be an issue at all. Will have more questions this fall as we start the frame off on this blazer
Old 07-31-2012, 01:09 PM   #7
OldCreek
OldCreek's Avatar
I've got 35's with 4" and a 7' door. With no top I barely clear the door by an inch or two. The door hangs down below the frame by an inch or two, also.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 08-05-2012, 09:57 PM   #8
ol'blu72
Worst case scenario let a little air out of the tires. Thats what my buddy always did with his crawlers.
Brad
72 Blazer CST 350/350/205
ol'blu72 is offline   Reply With Quote
