08-04-2012, 10:50 PM | #1 |
Decisions, Decisions...................
New to this site and wanted some opinions. I just picked up a 1947 1/2 ton and is in sorta okay shape. Some rust here and there such as in the floor but nothing I would consider too terrible. I will be disassembling the truck very soon and will be doing a very mild custom build on this.
The side cowl panel on the drivers side may need to get replaced as it was pushed in by the driver's door at some point. The opinions I was looking for was whether you would keep the side vent on the diver's side or not? I know these vents were only on '47 - '49 pickups, if I remember correctly, and am not sure if it is worthwhile to save the side vent. I will be adding a/c to this truck if that makes a difference. Dan |
08-04-2012, 11:54 PM | #2 |
Re: Decisions, Decisions...................
Welcome Dan, from So Arizona !
If you are adding A/C I would remove anything that will let outsind air in !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
08-05-2012, 10:31 AM | #3 |
Hi Dan, I am the opisite of a lot of guys on this. I like the cowel and driver side vents.
my 52 and a couple more we have are bent there.I am thinking about installing one when I repair the panel. You can't beat the fresh air inthe spring it the mountains. Just my $0.02. Oh and I am going to install AC. |
08-05-2012, 12:59 PM | #4 |
Thank you for the replies so far. I like the idea of the side vent and I may keep it if I can. I don't know how the side vents are regarding leaks or adding to a lot more road noise. The simplest fix, I guess, would be to put in a new side cowl panel w/o the vent and call it good. I've got a little time to consider this.
Dan |
08-05-2012, 11:01 PM | #5 |
I got rid of mine, trying to keep debris and water from getting between the inner and outer cowl, promoting rust again now that it's all fixed. A/C and the cowl vent will do it for me.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
