Old 08-06-2012, 03:45 PM   #1
not2oldchevy
Gto exhaust manifolds help
Have a 53 AD with a 5.3 I am trying to use factory manifolds. Tried stock truck they were about 2 inches too wide on each side. Bought some 06 GTO manifolds, they were about 1/2 inch too wide, already boxed the frame so I don't want to notch it. Anybody got any suggestions? Got plenty of manifolds I don't need! GTO manifolds look like they would flow super good but I don't want to notch.
not2oldchevy is offline   Reply With Quote
Old 08-06-2012, 03:50 PM   #2
Larry Lindley
Re: Gto exhaust manifolds help
I used factory manifolds,but had to notch frame,then later I switched to Hooker LS headers for 55-56 chevy car.
Larry Lindley is offline   Reply With Quote
Old 08-06-2012, 04:04 PM   #3
not2oldchevy
Block hugger or full length?
Old 08-06-2012, 06:13 PM   #4
Super73
Super73's Avatar
C5 Z06 manifolds? Tri-Y design and fit a bit tighter to the block.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-06-2012, 07:29 PM   #5
Larry Lindley
I used the full lenght ones,Hooker also make LS cast iron headers that tuck in tight,check Summit Racing forgot the part#.hope this helps.the corvett Zo6 is another try Ebay,or there site vendors that can help.
Old 08-06-2012, 07:46 PM   #6
Daaaanz67
Check out my post "FYI hookers" the new cast iron manifolds.
Daaaanz67 is offline   Reply With Quote
Old 08-07-2012, 01:11 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I got tbss, fit pretty darn good. Only thing I would change to is long tubes for performance if i redo the rest of the exhaust in stainless.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-08-2012, 11:30 AM   #8
nacho55
I have a 5.3 in my AD truck, with an S-10 Front clip, and if you are handy with a welder you can cut off the factory flanges from the cast iron manifolds and weld on a a different collector,(yes you can Mig weld cast iron if preped right) i used some steel v-band flanges and clamps and worked out good for mine, a person could also weld on a bend or elbow in a different position and put on a different collector on to be routed a little different to get you the clearance you need.
Just something to think about,
nacho55 is offline   Reply With Quote
Old 08-08-2012, 12:08 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
^^even better if you want to flip them to run as turbo manifolds.
and heck ya you can weld cast....just gotta cook it in the oven first
