Porterbuilt Forward Arms Series - control arms sale
We're proud to introduce our new Forward Arm Series control arms this month with an exclusive sale.
Description: Porterbuilt new Forward Arm Series tubular control arms were designed to help center the front wheels in the wheel opening on trucks using factory cross-member configurations, or chassis that have been Z'd and are still using a factory cross-member. They're built using the same thick-wall DOM tubing and CNC cut 3/16 pickeled plate steel as all our other arms. All bushing pivot tubes and ball joint cups are TIG welded. We also use a machined delrin bushing to minimize deflection;eliminate squeaks associated with polyurethane; and to increase bushing life. - Centered front wheels. - Increased caster gains. - Available for air spring and coil spring applications. - Standard or narrowed widths. - Will NOT work on Dropmembers. Strictly designed for stock cross-member applications. - Retail prices start at 1,049.00 for a complete set of Forward Arms. ![]()
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
