Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 08-13-2012, 08:16 PM   #1
peglegs
peglegs's Avatar
Stereo stays on for 5 sec.
when i press the on button it lights up for 5 secounds then shuts off. when i got the truck the po had it hooked up with key on only i found a constant hot & now it only stays on for 5 secounds changed it back & also tried other terminals i found a site for manuals http://www.manualsonline.com/ butdidnt have one for mine its a JVC KD-S88BT any suggestions? ty
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 09-21-2012, 07:02 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Stereo stays on for 5 sec.
Have you tried bench testing it out of the truck with a battery and see if you get the same result?
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-21-2012, 07:19 PM   #3
BIGTEN
BIGTEN's Avatar
I just got that same stereo and it did the same thing without the key in but with it in it works.
BIGTEN is offline   Reply With Quote
Old 09-22-2012, 09:43 PM   #4
1970/327/c10
1970/327/c10's Avatar
you have two wires. one is the constant hot wire that has to be hooked your constant power and the other one has to be hook your key so it only works when you turn the key on.
1970/327/c10 is offline   Reply With Quote
Old 07-05-2013, 06:03 AM   #5
stephenmeeker
stephenmeeker's Avatar
Usually, yellow runs to key, which I ran mine to the fuse box, and red is battery.
stephenmeeker is offline   Reply With Quote
