Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 08-14-2012, 01:27 AM   #1
mygirlz55
Frame welding?
Going to be doing a camaro front clip swap on our truck, want to know what welder I should use. How big do I need to go? Wire fed or arc welding? Have done some welding, just the first time welding a frame.
mygirlz55 is offline   Reply With Quote
Old 08-14-2012, 10:03 PM   #2
hugger6933
Re: Frame welding?
I would definatly look for a wire welder with a 220volt plug so it will have the ability to get hot enough to get good heat penatration. Make sure everything is of course clean and ground out to a bevel to help the wire flow path. Jim
hugger6933 is offline   Reply With Quote
Old 08-14-2012, 10:30 PM   #3
cableguy0
Re: Frame welding?
Dont take offense to this but if your asking this question you probably shouldnt be welding a frame. It takes time and experience ti know when your welds are structurally sound. This is not a place to "learn" A failed weld can end in someones death in this situation. To answer the question a miller 210 or equivelant would be a good choice.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-15-2012, 01:46 AM   #4
mygirlz55
Re: Frame welding?
Originally Posted by cableguy0 View Post
Dont take offense
No offense taken, I got some different opinions from people in regards to wire feed vs arc so thought I would ask here too. I'm sure I will have no problems with it just seeing what others have done and how it turned out. Still no response from someone who has done a frame swap????
