Old 08-16-2012, 03:40 PM   #1
Bulldog88
What radiators and fans are you using?
What radiators and fans are you using when doing ls swaps with out spending alot of money
Bulldog88 is offline   Reply With Quote
Old 08-16-2012, 04:15 PM   #2
softballnrd27
Always a work in progress
softballnrd27's Avatar
Re: What radiators and fans are you using?
I used a champion radiator and electric fans. It is a nice piece and I believe it was right around $300 total. I bought it from a company on ebay but I can't remember the name off hand.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 08-16-2012, 04:34 PM   #3
Daaaanz67
Stock new replacement Murry three core with built in trans cooler 215.00 Camaro fans I picked up for 50.00
Daaaanz67 is offline   Reply With Quote
Old 08-16-2012, 05:38 PM   #4
jsbgump
Gone Fishing
jsbgump's Avatar
I'm going to run one of the 200 buck aluminum ebay radiators and the stock clutch fan on mine
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 08-16-2012, 09:47 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Stock 4core with an Old Air Products dual e-fan/shroud assembly made for '67-'72 trucks
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-17-2012, 01:06 AM   #6
mcmlxix
Collector of Projects
mcmlxix's Avatar
My plan is AFCO 80126N aluminum dual pass with the correct inlet and outlet on the passenger side. The fan will be either the 97 Lincoln Mark VIII or the Jeep Grand Cherokee... Just havent pulled the trigger yet...
Rich
1972 K5 Blazer CST Click HERE
Old 08-17-2012, 07:59 AM   #7
whitels1
whitels1's Avatar
Stock, with 98 Windstar fans, with only 1 fan working in the pair, it still never sees over 205, even when it's 110 outside.
whitels1 is offline   Reply With Quote
Old 08-17-2012, 10:07 AM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I have a Champion with their dual electric fans. works perfectly.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-17-2012, 11:55 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm running a be-cool sbc radiator w/ custom hoses setup for Lsx.
I have whatever fan was sent with the be-cool kit 5 years ago.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-17-2012, 01:47 PM   #10
ls1nova71
ls1nova71's Avatar
Stock radiator with the stock clutch fan that came on the engine. Fits in the original fan shroud, works great.
I've never been a real big fan of electric fans, they work alright but draw tons of power. Of course some cars you have no other option so you have to use them, but if at all possible, I'll use an engine driven fan. Last year just outside of Las Vegas I had a weather pack connector on my '33 Ford melt down and then its no fan at all. Was alright when I was moving, but she heated up fast when stopped.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-17-2012, 04:02 PM   #11
gringoloco
A guy with a truck
gringoloco's Avatar
Do you have pics of this installation? I have seen them used on Chevelles, which are very close in size to our truck rads. Just curious how you tackled it, as I have liked the work I've seen you do thus far.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-17-2012, 04:46 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
There's pages of back and forth on this. Last thing I read said that the load required for a brand-name efan was still less than the equivalent for a mechanical. Plus its only on when it has to be.
Part of the issue with those who have insufficient cooling with an e-fan is
A. they bought a crappy fan with too low of cfm for what they need
B. They are using a pusher as a puller or vice versa and losing cooling capacity.
C. They aren't running a shroud and are wasting air
D. Its programmed or wired wrong
E. Wired like crap and when the fan kicks on it creates too much of a draw.
Most of us with lsx swaps have an alt. that is more than double what we need, no good, properly wired fan should over-draw the system.
Old 08-17-2012, 06:31 PM   #13
68GMCCustom
My Old Air Products e-fans have cooled both my 383stoker/turbo350 combo and now, my 6.0L efi motor. 1 fan running will generally keep it at 185* or below...2nd fan is usually not on long. Had them since 2009 w/o any issues. Oh wait, I have had one relay go out I had to replace, but that's all.
Kurt -
Old 08-17-2012, 06:31 PM   #14
mooseknuckles
mooseknuckles's Avatar
griffin universal two core rad, dual elec. fans...never ever gets hot....
mooseknuckles is offline   Reply With Quote
Old 08-17-2012, 11:35 PM   #15
whitels1
whitels1's Avatar
Much appreciated, here are a few pics, I ended up welded a few tabs off of the radiator support out of 1/8" steel, bottom slides into a groove and top bolts on. Fit's just about purfect, I had to do some plastic trimming but not to bad. They are controlled by the pcm, 30A breaker to a 30amp relay for both fans.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 08-18-2012, 08:36 AM   #16
5150
C10 Club Tennessee
5150's Avatar
I plan on using the factory fan on my 5.3 with the factory 67-72 radiator and shroud. If this is possible. I'd like to see pics if anybody has any.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 08-18-2012, 08:39 AM   #17
mcmlxix
mcmlxix's Avatar
Originally Posted by 5150 View Post
I plan on using the factory fan on my 5.3 with the factory radiator and shroud. If this is possible. I'd like to see pics if anybody has any.
The radiator is a couple inches wider then the 67-72 trucks... so I think it will take alot ot make it fit...
Rich
Old 08-18-2012, 08:40 AM   #18
5150
C10 Club Tennessee
5150's Avatar
No, I meant the factory 67-72 radiator and shroud. I fixed my confusion.
Bryan
www.gmtruckshow.com
Old 08-18-2012, 08:48 AM   #19
mcmlxix
mcmlxix's Avatar
If you mean an electric fan, I emailed someone on eBay for dimensions and it too wide.... If you meant the mechanical fan attached to the water pump, somone tried it with a mid 80's square body and was looking for a spacer to get the fan into the factory shroud... I guess it depends on how far back the motor ends up.... havent seen any 67/72 with mechanical fans....
Rich
Old 08-18-2012, 09:28 AM   #20
5150
C10 Club Tennessee
5150's Avatar
No, I mean using the mechanical fan from my 5.3 with 67-72 shroud and an original style radiator. If possible, of course.
Bryan
www.gmtruckshow.com
Old 08-18-2012, 10:27 AM   #21
Clyde65
Clyde65's Avatar
This is what LS1nova did above.
Clyde65
Rebuild of Clyde
support our troops!
Old 08-18-2012, 02:14 PM   #22
ls1nova71
ls1nova71's Avatar
You beat me to it! But yes I have the '72 radiator and shroud with the 6.0 clutch fan. There are pics in my build thread in my sig.
Old 08-18-2012, 10:27 PM   #23
Daaaanz67
My three core with camaro fans kept my truck at a cool 200 idling in 104 degrees that's with both fans running
