Old 08-18-2012, 09:36 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Bagged Suburban Guys??
Where are you guys putting your tank and compressor at. Mine's been on schrader valves for a while and I'm about to install my Air Ride Technologies digital air gauge and sensors. Just trying to find the best place where it's not too loud.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 08-18-2012, 09:39 PM   #2
vectorit
What?
vectorit's Avatar
Re: Bagged Suburban Guys??
Check out the build area for the burbs, there are a couple builds in there that may help answer your question.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-19-2012, 09:58 PM   #3
kev2809
low n' slo
kev2809's Avatar
heres what i did with a 5 gallon tank.
[IMG][/IMG]
little dusty...right now i have one comp but will be getting a dual pack before it hits the road. im going to make another bracket to hold 2 of them right where the single one is at now..
the tank bracket is (2) pieces of 2" square tubing welded togeter to raise it up..then its bolted to the frame. the cross plate is 3/16" plate that i bolted the air tank to. no way the tank would work with those brackets without raising it up..it barely clears now.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 08-20-2012, 02:55 PM   #4
Hart_Rod
Hart_Rod's Avatar
I mounted mine to the bottom of the rear floor between the gas tank and bumper.
Hart_Rod is offline   Reply With Quote
Old 08-20-2012, 03:06 PM   #5
kev2809
low n' slo
kev2809's Avatar
are those pics with the truck laid out?
-_--_--_ _________
Old 08-20-2012, 06:04 PM   #6
Hart_Rod
Hart_Rod's Avatar
Kev are you talking about my burb?
Old 08-20-2012, 06:21 PM   #7
kev2809
low n' slo
kev2809's Avatar
ya, just trying to reference how far that is from the ground when aired out.
-_--_--_ _________
Old 08-20-2012, 07:06 PM   #8
Hart_Rod
Hart_Rod's Avatar
Kev - it's probably 8" off the ground when aired out. I'll try to take some good pictures the next time I get a chance.
Old 08-20-2012, 07:19 PM   #9
Hart_Rod
Hart_Rod's Avatar
Here's the best I can do right now. it's not quite as low as it appears because I have the front on jack stands.
Old 08-20-2012, 09:34 PM   #10
project 67 sub
project 67 sub's Avatar
here is where i have mine mounted at. not exactly the quietest spot because i have the rear valves mounted directly to the tank, but then again my burb isnt exactly quiet anyways.... doesnt help that i dont have a rear floor lmao
but anyways its just another idea. oh! its a 9 gallon tank, and the rear valves will be getting relocated to below the rear floor once i build it. but the tank will most likely stay their.
and if you want an idea where to mount the front valves this is where i have mine at
project 67 sub is offline   Reply With Quote
Old 08-21-2012, 07:18 AM   #11
5150
C10 Club Tennessee
5150's Avatar
I ended up mounting the tank and compressor under the third door on the frame.
Bryan
www.gmtruckshow.com
Old 08-21-2012, 06:21 PM   #12
kev2809
low n' slo
kev2809's Avatar
must have a skinny tank, mine wouldnt work there.
-_--_--_ _________
Old 09-04-2012, 12:02 AM   #13
bruin_d
bruin_d's Avatar
Might help...
bruin_d is offline   Reply With Quote
