Old 08-21-2012, 03:23 PM   #1
Nitschke
Nitschke's Avatar
Will this DBW work for me?
The pedal assembly is from a 2008 gmc sierra 1500 for $25. The motor is an ly6 from a 2009 the 6l80e from a 2010. Going in a 1972 chevy pickup. the question is will this pedal assembly work for my application? Thanks.
~72 Chevy Truck~
Motor: LY6 6.0 Liter
Trans: 6L80E
Still under construction
Nitschke is offline   Reply With Quote
Old 08-21-2012, 06:25 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Will this DBW work for me?
As far as I know....the '07up trucks use the same pedal. My truck is also an LY6....you'll want the "all plastic" pedal and assembly.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-22-2012, 01:36 AM   #3
Nitschke
Nitschke's Avatar
Awsome thank you! Do the 07+ have tack module like the others?
~72 Chevy Truck~
Trans: 6L80E
Old 08-22-2012, 01:43 AM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
07 was the cut over year.... if you have the newer E38 computer, I'm pretty sure there is no TAC module.
e38
Rich
1972 K5 Blazer CST Click HERE
Old 08-22-2012, 08:35 AM   #5
68GMCCustom
I have the bottom ECM in the pic
Kurt -
Old 08-22-2012, 07:34 PM   #6
clinebarger
Gen IV engines do not use a TAC module.
Some help with PCM identification....These PCM do not have transmission functions, So if your running a "E" trans you need a TCM.
EDIT...You have a 6 speed....TCM is in the trans, sorry.
clinebarger is offline   Reply With Quote
