08-22-2012, 06:21 PM | #1 |
blower motor resistor
I have a 2000 Silverado---Where is the blower motor resistor located and how do you replace it?
08-22-2012, 07:09 PM | #2 |
Re: blower motor resistor
Its left of the blower motor, Bolted to the HVAC case, Check the harness for melted/burned terminals, If it is get a "pigtail" from GM & splice it in.
08-23-2012, 07:26 AM | #3 |
There is an extended warranty issued by gm on these trucks. There's a good chance you could get a new resistor and pigtail installed by gm at no charge.
Posted via Mobile Device |
08-23-2012, 12:27 PM | #4 |
I just had that done on an '03, It's only covered on trucks under 150,000 miles or in service 10 years or less, which-ever comes first. I made it by about a half of a month. Otherwise, I think the bill would have been around $160.00.
08-23-2012, 12:40 PM | #5 | |
Charlie Daniels w/ a Tq Wrench
As they said it is in the air duct under the glove compartment by the blower motor. The resistor is actually in the air way, remove the cover, then remove the two screws holding it in as shown above. And be sure to check for burned/melted terminals or you will likely burn it up quickly again from excess resistance.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
08-24-2012, 06:21 PM | #6 |
The resistor is around thirty dollars but the pigtail is around 75 dollars. Then add on the labor time.
10-07-2012, 11:30 PM | #7 |
Here is a couple pics of a bad one on my truck 2005 silverado.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car |
10-17-2012, 04:56 PM | #8 |
i have a 2003 silverado, and was wondering by replacing the resister, would all the functions on my heater control such as the 1 2 3 4 5 work?, right now only 4 and 5 work the heater works great, on 4 and 5, just nothing not a noise or nothing on 1 2 and 3, any help on this would be great thanks
10-17-2012, 05:02 PM | #9 |
Cured mine. I was lucky enough to have it covered under the recall notice (10 years or 150,000 miles, made it by 2 months!) Most dealerships have the parts in stock because of it being such a wide spread problem. With labor it will run you about $160.00. LMC also carries the resistor and matching wiring pig-tail (Probably a Taiwan nock-off) but its a fairly straight-forward plug-and-play deal. Good luck!
10-17-2012, 08:50 PM | #10 |
Is this something a dealer has to do? Or can i do this? And is the resistor in the same spot on a 2003 as they are on the older 99hitman to 2002the silverado? Thanks again for the help
10-23-2012, 03:27 PM | #11 |
Real glad you guys were discussing this. I just picked up an 05 Tahoe & #5 is out but she's got 141k on the ticker. I'll take it in & see if they will do it under recall. THANKS a bunch!!
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) |
