![]() Join Date: Apr 2010
Gauge problems with 04 Yukon
Anyone had issues with the gauges on thier trucks? I have an 04 Yukon XL K2500 that suddenly spiked the oil pressure and voltmeter.
I had to replace a PCM about 2 months ago, due to it not allowing the alternator to charge. The mechanic that flashed the PCM told me that it was likely caused by a voltage spike, and all I had to do was to sweep the gauges back. I have physically checked oil pressure and voltage, and both are normal. I have tried sweeping the gauges back with a magnet, as well as removing the faceplate and manaully sweeping them back. Magnet did nothing, sweeping them manually makes them work when I start the truck for the first time, but when I shut it off the needles stay, then spike the second time I start it. Truck gives no codes, Kinda at a loss at this point. Any info or advice would be helpful. thanks
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
![]() Join Date: Sep 2005
Re: Gauge problems with 04 Yukon
The clutsers are bad about the stepper motors going out
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
