Aim Headlights. Anyone Got A Haynes Manual Handy?
Howdy All,
I spend 95% of my time over in the 73-87 forum, but i will likely be in here a bit now with my 02 Sierra. I tossed some new headlights and bulbs into it today and they are out of whack. Bad. When I had a dodge I remember finding measurements in the haynes manual for aiming headlights. X feet back from a wall X feet from the ground to the center of the light beam and X feet between the two I have little use for a hanyes manual otherwise i'd go buy one, just curious if some one had one and could look up what i these measurements are for me I could eye ball it... but then there is a reason i am not a carpenter or any sort of fabricator. Much Appreciated, Scott
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims. |
Re: Aim Headlights. Anyone Got A Haynes Manual Handy?
Here's the diagram out of my Haynes manual. 25 ft back from wall, tape a line on the wall of the same height of the center of your headlamps from the ground. When you turn the lights on center the light with the tape.
![]() Posted via Mobile Device Posted via Mobile Device
![]() ![]() ![]() ![]() ![]() ![]() My first (1984 c10) Build |
Man, I hope one day i can start contributing to this board the way guys like you do
Thank you very very much
No problem at all! I haven't been on this forum in a while since I sold my 84 (
Yeah i used to be a regular on fullsizechevy till i discovered this place...
