Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 09-21-2012, 11:13 AM   #1
Ackattack
Ackattack's Avatar
97 SAS and more
Just a cross post incase all you 4 wheel types haven't seen it.
I'm building a 97 crew cab C3500. It started as a 454 powered dually. I'm putting in a 94 6bt 12V cummins, dodge nv4500, dodge transfer case. I'm also using the D60 front and D80 rear.
For the front I'm going to use long radius arms and the stock dodge coil springs.
For the rear I'm going to use the stock GM leafs. For the D80 I have to move the spring perches outboard. I'll also be using some airbags over the leafs.
Oh, and I'm putting a shortbed fleetside on it.
Enjoy: http://67-72chevytrucks.com/vboard/s...d.php?t=526664
Ackattack is offline   Reply With Quote
