C-30 Complete front suspension(new)
This front end was removed from a recent project truck. All components have less than 3000 miles on them. This is completely assembled, ready to roll under your truck and bolt on. Crossmember is front a 1970 C-30 dually, converted to disc brakes. DO NOT have any dually wheels at this time.
New parts: Dorman Upper(2) and Lower(2) control arms assembled with new shaft kits, bushings and ball joints. New Brake Best front hub/rotor assy's w/ all new bearings, races, seals, castle nuts, washers and pins. New dust caps. Rebuilt calipers. (GM HD braking code JB8) New front brake hoses New Moog inner and outer tie rod ends. New Moog Idler arm Rebuilt power steering box assy Moog HD sway bar bushings GM HD sway bar(1 1/4") New Monroe Gas Magnum shocks All hardware and frame supports plates included. Asking price $1000/obo Truck freight shipping available for actual costs. Call or text 620-205-9369 Thank you! (sorry crossmember is updide down in pics-will update with better ones) tires/wheels in pics are for moving purposes only-front end requires actual dually wheels. |
Tags |
brakes, steering, suspension |
