Registered Truck Offender
Power steering pump options for LQ bracketry????
Guys any help here appreciated.
I have a sandrail with a stroked LS1 and the stock LQ truck accessory brackets. Issue is, the Gear-One R&P power steering lines require an- fittings. The previous owner hob-gobbed and brazed crap together to adapt to the an- hoses and of course it leaks pretty bad. I have searched for a Howe pump and remote reservoir or any aftermarket pump that would have NPT fittings on both pressure and return line, but NOTHING I can find will fit the stock truck accessory brackets. Has anyone found a power steering pump for the LQ bracketry that has NPT fittings for both pressure and return, with or without a remote reservoir ? Appreciate any thoughts / ideas or pointers Here is the mess I'm dealing with
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 10-05-2012 at 11:19 AM. Reason: add pict |
#2 | |
Re: Power steering pump options for LQ bracketry????
Get a new pressure regulator nut (the piece that they brazed the -6 on) 16mm to -6 AN adaptor fitting http://www.summitracing.com/parts/EAR-961955ERL/ To adapt the pressure side to AN. The easiest thing on the return side is to cut the fitting off the hose & use a clamp. Or use a braze-on -6 JIC...Example http://www.spokanehose.com/product.php?id=3457 Available at any industrial hydraulic supply. Brazing the return side is fine. If you dont know how to braze take it to a welder. |
