Old 10-07-2012, 03:27 PM   #1
GEARBOXGARAGE
Msc. '63-'72 suspension parts
Posted this earlier in the '60-'66 parts board, but some parts also fit '67-'72. Follow this link to the post for pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=546466
Thanks,
Mike
We have a mix of extra/left over parts from a '66 build. All parts are new, only installed during mock-up, 0 road time.
1) One set of POL Tubular A-arms, with new MOOG '63-'70 Ball joints installed, powder coated silver. Will fit '71-'72 with correct ball joints installed--$700.00
2) Early Classic '63-'66 Front Sway Bar, 1-1/4" Diameter, w/ lowered frame-mount brackets. Will also fit POL A-arms listed above--$125.00 SOLD
3) One pair of Early Classic front small block, stock height springs--$90.00
4) Can type Power Steering Pump w/ mounting bracket and High Pressure hose--$125
5) Upper shock mount reinforcing kit, CPP Brand, w/ mounting hardware--$25.00SOLD
6) Raybestos Brake calipers and pads for 1-1/4" rotors. Never had brake fluid ran through them. Originally purchased through Early Classic at $85.00 each (ROTORS NOT INCLUDED) -- $100.00 for the pair.SOLD
SWAY BAR SOLD. REASONABLE OFFERS CONSIDERED ON OTHER ITEMS
GEARBOXGARAGE is offline   Reply With Quote
Old 10-15-2012, 08:44 AM   #2
GEARBOXGARAGE
Re: Msc. '63-'72 suspension parts
Sway bar sold. Reasonable offers considered on other items.
Thanks,
Mike
Old 10-15-2012, 09:35 AM   #3
69truckin
69truckin's Avatar
can you post a pic of the power steering pump?
69truckin is offline   Reply With Quote
Old 10-15-2012, 10:17 AM   #4
missinfishin10
Amazed Member
missinfishin10's Avatar
Mike, I'll go $100.00 shipped on the calipers. The should fit my 71 GMC don't you think?
P.M. me details
Thanks! Jeff
71 LWB Fleetside
1950 3100 Original Project!
missinfishin10 is offline   Reply With Quote
Old 10-15-2012, 11:53 AM   #5
GEARBOXGARAGE
69truckin--I have pics in the following thread....
http://67-72chevytrucks.com/vboard/s...d.php?t=546466 Sorry, link didn't want to connect. The link at the beginning of this thread works, though and will take you to the pics.
The pump includes the chrome pulley and high pressure hose.
P.M. me details
Thanks! Jeff
Jeff, sending you a PM. Yeah, they are the factory style truck calipers for 1-1/4" wide rotors.
Thanks,
Mike
Last edited by GEARBOXGARAGE; 10-15-2012 at 11:55 AM. Reason: copied link didn't work.....
Old 10-15-2012, 01:40 PM   #6
missinfishin10
Amazed Member
Paypal sent for calipers Mike!
Thanks!
71 LWB Fleetside
Old 10-15-2012, 02:41 PM   #7
GEARBOXGARAGE
Here is a pic of the P.S. Pump
Thanks,
Mike
Old 10-15-2012, 06:43 PM   #8
HotRod C/10
HotRod C/10's Avatar
Ill take the reinforcement shock mounts for 25 shipped.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 10-15-2012, 09:17 PM   #9
GEARBOXGARAGE
Sounds good, $25 shipped. Send me a PM with your contact info and we can get things rollin'
Thanks,
Mike
Old 10-15-2012, 10:30 PM   #10
HotRod C/10
Originally Posted by gearboxgarage View Post
sounds good, $25 shipped. Send me a pm with your contact info and we can get things rollin'
thanks,
mike
on the way
LS SWAPPED
-1976 SILVERADO
Old 10-16-2012, 08:38 AM   #11
GEARBOXGARAGE
Calipers and Shock Reinforcements SOLD
Old 10-19-2012, 06:52 AM   #12
missinfishin10
Amazed Member
I got the calipers Mike, They look great!
Thanks! Jeff
71 LWB Fleetside
Old 10-19-2012, 02:37 PM   #13
GEARBOXGARAGE
Thanks! Jeff
Thanks for the heads up that they arrived, enjoy!
Mike
Old 10-20-2012, 10:01 AM   #14
HotRod C/10
on the way
Got em yesterday!.....Thanks
LS SWAPPED
-1976 SILVERADO
Old 10-22-2012, 08:43 PM   #15
capt68
capt68's Avatar
Mike,
I got the control arms today. They look great. Thanks.
Russell
capt68 is offline   Reply With Quote
Old 10-23-2012, 04:53 PM   #16
GEARBOXGARAGE
Originally Posted by capt68 View Post
Mike,
GREAT! Don't forget our conversation about the ball joints. If you're running the later model disc brake spindles, make sure to use the ball joints that match. Those are brand new MOOG units installed on the arms for '63-'70, so if you can't use them, I'm sure they would sell quite easily on this site.
Let me know about that ididit column, as well.
Thanks,
Mike
