Old 10-12-2012, 06:11 PM   #1
RRR18
RRR18's Avatar
More Lift
Hey boys! Need some help. I just got new wheels/tires on my '03 Silverado 1500 4WD. It has a 6" lift kit on already. I can lift the rear up more in many different ways no problem. My question is what to do about getting the front up a bit more? Should I crank on the torsion bar key bolts or get leveling torsion bar keys themselves? I'm tryin for 2" more. Of course I know whichever way I go I'll need an alignment. Or if you think of different way lemme know. Thanks.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 10-14-2012, 11:13 PM   #2
RRR18
RRR18's Avatar
Re: More Lift
Nobody?
'67 BAD IDEA
Ryan
Old 10-18-2012, 07:50 PM   #3
1978steven
1978steven's Avatar
Re: More Lift
I'd start by using the stock torsion bolts and hopefully that will get you where you want to be. But if you go with leveling keys be very careful not to over crank them bars, the ride will suffer severely, and your front end parts will wear out quicker then you can replace them because of the severe angles they will be set at...
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
