Old 10-14-2012, 05:43 PM   #1
byeoficr
86 High Sierra
Here is my farm find. got it for $1000. Her daughter wrecked it and they were told the frame was bent, So they parked it and it sat for about five years.
byeoficr is offline   Reply With Quote
Old 10-14-2012, 05:56 PM   #2
byeoficr
Re: 86 High Sierra
the engine is in need of some serious help. It hardly runs doesn't downshift properly has no response. so time to freshen the 305 up. I know the 305 the world best boat anchor I've heard them all. but whatever i use will bolt on to a 350 when the time comes. trans fluid has some miles on it but not burnt and the transfer case works fine.
Old 10-14-2012, 06:02 PM   #3
byeoficr
Re: 86 High Sierra
Here are some tear down pics.
Old 10-14-2012, 06:03 PM   #4
byeoficr
Re: 86 High Sierra
Q-jet gone!
Old 10-14-2012, 06:07 PM   #5
byeoficr
Re: 86 High Sierra
look at the surprise I found under the intake! Years of neglect. That is a load of carbon. sorry about the image quality.
Old 10-14-2012, 06:12 PM   #6
byeoficr
Re: 86 High Sierra
All cleaned up and ready for assembly.
Old 10-14-2012, 07:17 PM   #7
UPNADM
UPNADM's Avatar
Re: 86 High Sierra
Wow, I am sure your performance will be greatly improved after this clean up... Good work.
UPNADM is offline   Reply With Quote
Old 10-14-2012, 08:34 PM   #8
byeoficr
Re: 86 High Sierra
Now things are looking better
Old 10-14-2012, 08:37 PM   #9
byeoficr
Re: 86 High Sierra
All buttoned up! Found a coolant leak
Old 10-14-2012, 08:41 PM   #10
byeoficr
Re: 86 High Sierra
Running much stronger. Still need to do some carb adjusting.
Old 10-14-2012, 08:45 PM   #11
x ReAcT x
Re: 86 High Sierra
Your doing a great job, already looks 110% better!
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
x ReAcT x is offline   Reply With Quote
Old 10-14-2012, 08:46 PM   #12
byeoficr
Re: 86 High Sierra
Couldn't reuse the valve covers so decided on some cheap chrome ones. It's amazing what sitting will do
Old 10-14-2012, 08:51 PM   #13
byeoficr
Re: 86 High Sierra
Figured out the coolant leak. I didn't lube the o ring under the water neck. And upon closer inspection I put the fuel filter on backwards.
Old 10-14-2012, 09:32 PM   #14
JRANGER
JRANGER's Avatar
Re: 86 High Sierra
Nice man... Good to see another High Sierra not too far away
JRANGER is offline   Reply With Quote
