Old 10-17-2012, 07:00 PM   #1
David623
72 Jimmie rebuild
Hello I am just starting a project on a 1972 Jimmie, my plans is to upgrade the motor to a 2003 5.3 Vortex motor along with the automatic w/overdrive and the transfer case that came with the engine. Also the wiring harness to run the motor. The frame has been blasted and painted already, the rear differential (posi-trac) has been rebuilt and painted, I stayed with drum brakes in the rear. The front differential is being rebuilt right now the gears seem to be ok had a little difficulty finding inner seals but my brother found the parts. All new disc brake parts and should be ready to put a rolling chassis together soon. New leaf springs front and rear. And of course new ss brake lines.
I just started on the body this part has me a little worried, but finding this web site I think will help a lot. I will post some pic soon.
David623 is offline   Reply With Quote
Old 10-17-2012, 07:35 PM   #2
briank
Re: 72 Jimmie rebuild
Welcome and good luck! Keep us posted with pics
briank is offline   Reply With Quote
Old 10-17-2012, 07:54 PM   #3
hilljob26
hilljob26's Avatar
welcome,, i am basically doing the same as you,,make sure you get a lot of pics...i take some everytime i do something
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 10-17-2012, 09:13 PM   #4
Slinger60
Slinger60's Avatar
Welcome. Looking forward to seeing some pics.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=529970
Shawn
Slinger60 is offline   Reply With Quote
