Old 10-18-2012, 08:19 PM   #1
68chevy92
03 silverado a arm problms
My friends 03 silverado front end is messing up I thought. It was the bearings but its actually the bolts that connect the rotor. To the a arms. There letting. The tire n rotor move top to bottom. Bottom rubber boot . Is ripped up but top is fine . has bout half inch of play in it any one know how to fix that new grease or new bolts? It is 2wd but its lifted Thanks matt
68chevy92 is offline   Reply With Quote
Old 10-18-2012, 09:43 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 03 silverado a arm problms
Are you talking about the ball joints? They are the joints between the a arm and spindle. They need to be pressed out if the a arm to be replaced.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 10-19-2012, 10:08 AM   #3
1978steven
1978steven's Avatar
+1, sounds like the ball joint are blown and in desperate need of replacement...
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
Old 10-19-2012, 03:05 PM   #4
truckdude239
truckdude239's Avatar
is this the part your talking about its a ball joint replace them
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-21-2012, 03:04 PM   #5
RRR18
RRR18's Avatar
^^^Pics always help^^^
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 10-21-2012, 06:37 PM   #6
truckdude239
i just happened to have one of these truck in my shop when i read the post pictures are worth a thousand words
David fuller
2000 Tahoe 5.3l 378
