Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-21-2012, 03:19 PM   #1
502ms
502ms's Avatar
Weird Lighting Phenomenon
I have noticed that when I have my headlights or parking lights on, my rear lights do not have indication of stopping or turning (signal). When no lights are on (parking or headlights), they work fine. This was the case before I rewired the entire truck with the painless harness for 67-72 trucks, and has not changed even with the LED tails. Is there an assembly that needs to be adjusted under the dash? Just curious.
Everything else works the way they should.
1972 Chevy C10.
Thanks in advance.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 10-22-2012, 07:09 AM   #2
cdowns
cdowns's Avatar
Re: Weird Lighting Phenomenon
bad ground
Old 10-22-2012, 10:39 PM   #3
W.I.P.72
W.I.P.72's Avatar
Yeah ground is the only thing i can think of if you just replaced all the wires.
OKLAHOMA MEMBER MEET JUNE 15, MIDWEST CITY OK.http://67-72chevytrucks.com/vboard/s...d.php?t=559886
72 C-20 Stepside - Work In Progress
W.I.P.72 is offline   Reply With Quote
Old 10-26-2012, 03:55 AM   #4
502ms
502ms's Avatar
Any ideas of what else can be grounded? My engine has new battery cables, ground cables and I did not see anything in the cab that needs grounding...
Best Regards,
Leon M.
Old 10-26-2012, 06:21 AM   #5
bk2life
not exactly sure just makin a guess here, new updated wiring/fuse block, maybe try a new flasher.
not sure if that will do anything but making a guess.
dont think it is a ground be cause they work.
worng plug/wire placement in column/turn signal switch?
bk2life is offline   Reply With Quote
Old 10-26-2012, 12:24 PM   #6
cdowns
cdowns's Avatar
EACH AND EVERY LIGHT BULB NEEDS A GROUND and everything else for that matter in order for voltage to flow properly
Old 10-26-2012, 01:07 PM   #7
fixit-p
fixit-p's Avatar
It is a bad ground as already stated, most likely at the light buckets or bed to frame. With the headlights off the Brake/Turn lights have alternate ground paths available but once the lights are on it removes the alternate ground path. Best way to test the condition of the ground at a given circuit is to do a voltage drop test on the ground side of the circuit anything over .2 volts indicates a bad ground.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
headlights, park lights, tail lights
