Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 10-28-2012, 08:56 AM   #1
scott-wisc
scott-wisc's Avatar
6x9 Box
After I remove the gas tank, I want to put a couple of 6x9 3-ways behind the seat of my '71. Is there any advantage to building a box versus store bought like pictured below? Does a bigger box produce deeper, punchy bass?
I made some temporary boxes to throw under the seats and they sound hollow and flat.
scott-wisc is offline   Reply With Quote
Old 10-28-2012, 03:41 PM   #2
_Ogre
_Ogre's Avatar
Re: 6x9 Box
6x9 won't give you a whole lot of base and having them under the seat will muffle your highs and mids
a subwoofer under the seat works because base will travel thru the seat
if you can't see your tweeter you won't get the highs
if you make your own box, you might be able to angle them out towards the doors and pick up some more mid range
if you want more base look at the interior build link in my signature
while my gas tank enclose is for my 58 it could easily be modified to your 71
shop air compressor timer
Old 10-28-2012, 04:02 PM   #3
bigblock73
yeller
bigblock73's Avatar
Re: 6x9 Box
I make 6x9 cab corner brackets for 67-72, check my signature to learn more about them. If you have any questions, let me know.
bigblock73 is offline   Reply With Quote
Old 10-30-2012, 06:16 AM   #4
scott-wisc
scott-wisc's Avatar
Re: 6x9 Box
Does anyone know if there is a differance in sound quality between the store bought small boxes versus one large box with the speakers pointing out the sides?
Old 10-30-2012, 11:32 AM   #5
jimmydean
jimmydean's Avatar
Re: 6x9 Box
I would use these over the store bough crap myself. I'm not a fan of pre made enclosures simply because building one yourself correctly is very easy to do and can be made to fit your space vs. "one size fit some" with inferior materials.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-01-2012, 04:47 PM   #6
_Ogre
_Ogre's Avatar
Re: 6x9 Box
a lot depends on where they're located and where the point
Old 07-05-2013, 06:00 AM   #7
stephenmeeker
stephenmeeker's Avatar
Re: 6x9 Box
Most 6x9s are infinite space speakers, so some do not like boxes. make sure you check the specs on the speakers before you buy anything. I run mine in panels on the floor wedged between the seat and floor, and they sound fantastic. I also run a high pass, because I have a sub and dont need much bass coming from them.
stephenmeeker is offline   Reply With Quote
