11-10-2012, 12:19 PM | #1 |
40 Gal suburban Gas Tank into 71 4x4 truck install.
Hi,,Have not been here for a while,,I have completed my conversion to a 1985 40 gal suburban gas tank mounted under the rear bed of a 71 4x4 long bed truck,,it turned out very nice and works great!
11-10-2012, 12:26 PM | #2 |
Re: 40 Gal suburban Gas Tank into 71 4x4 truck install.
Here are some video's (If I do this right?) How do you embed video's on this forum so they pop up in the post?
http://youtu.be/tbpNkkv7HoI http://youtu.be/2e-J_0_djjE |
11-10-2012, 12:39 PM | #3 |
Some more pics.
11-10-2012, 02:25 PM | #4 |
Looks Really good!!
11-10-2012, 02:54 PM | #5 |
1972 K20
Dave I watched your videos and that looks like a nice conversion for us 4x4 guys. Were you able to route the filler pipe without modifying the inside of the box? Thanks for sharing!
Posted via Mobile Device Posted via Mobile Device |
11-10-2012, 03:11 PM | #6 |
YES! I modifide the Gas Cap filler pipe from an angle to straight and had to shorten it,,I had to make a new hinge for the door so it would clear the inner wall of the bed and close properly as the stock set up would hit,,it is a very tight sqeeze but it worked fine,,I will build a surround around the gas cap area to look more Stockish,,The Tank is in backwards from where it was in the suburban as that is the only way the filler pipe would line up between the bed rails and that makes the gas door on the drivers side instead of the pass side.
11-10-2012, 03:16 PM | #7 |
Few More.
11-11-2012, 12:47 PM | #8 |
The Truck will need the extra gas as it has a built 396 under the hood!
11-12-2012, 03:18 AM | #9 |
Dave, looks great. I will have to refer to this when i go to do mine! THe one thing i was wondering is what to do for the fuel lines? I was also thinking about making the rear market light into the filler, but the idea of the gas door in the side of the bed has grown on me!
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT "Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C. "1968" C10 Shortbed project |
11-12-2012, 07:22 AM | #10 |
I'm glad to see you've done this. And,a great job at that! So,no moving anything on the frame? I have the 40 gal. from my '91 Suburban I was thinking about fitting into my '72 K2500...and lose the saddle tanks.
11-12-2012, 12:49 PM | #11 |
I used the fuel lines from the suburban and modifide them at the rear for easyer access in hooking them up,,also there is Cross member mods needed,,I blasted the rivots out of the stock spare tire cross members with a plasma cutter and took the tank cross members from the suburban and installed them. The video I made has better details
08-08-2014, 08:30 PM | #12 |
ok, I know this is an old thread...
how close is the tank to the rear axle? any interference possibility? Thanks- Eric
'06 2500 HD 4x4. manual transfer case, crank windows. '88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project. My trucks don't leak oil, they mark their territory. |
11-13-2014, 02:07 AM | #13 |
This is awesome! what year did you get the tank from? did you have to modify the frame to make it fit? Im very interested in doing this to my 71.
1971 Chevy K30 / 454 / TH400 / NP205 / Dana 60/14 bolt FF on BFG Baja 37's - Build Thread : http://67-72chevytrucks.com/vboard/s...d.php?t=647877 2018 Silverado 1500 5.3 LTZ Z71 - daily driver 2019 Tahoe Z71 5.3 - (Wifes daily driver) |
11-13-2014, 02:25 AM | #14 |
I watched the video and I'm pretty sure he got the tank from a blazer not a suburban so I question the actual capacity of the tank.
40 would be sweet |
02-18-2015, 11:25 AM | #15 |
Definitely a Suburban. You can see the four doors in many shots.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
02-18-2015, 03:34 PM | #16 |
Something that needs to be noted is the 40 gallon tank was optional.
If we look at his donor year, 1985, there were three Suburban tanks offered. 25 gallon standard production 31 gallon optional, RPO NK7 40 gallon optional, RPO NE2
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-18-2015, 04:01 PM | #17 |
Sweet catch! Thanks for the info.
Any idea if the crossmembers are identical across the three sizes of tank? Truck Shop has repro 40gal tanks and straps, all that would have to be removed from a donor vehicle (Pick n Pull) would be the crossmembers.
02-18-2015, 04:37 PM | #18 |
Good question and one I can't help with. PM'd Kieth Seymore on this one.... :-)
02-18-2015, 06:51 PM | #19 |
All about them K’s
My dad has a 40 gallon diesel suburban tank for his 72 k/20 not sure how he put it in I'll have to check.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
02-18-2015, 07:22 PM | #20 |
I have a 31 gallon Blazer tank I plan to put in my 72 Blazer. Thanks for writing this up.
02-19-2015, 02:05 PM | #21 | |
Not 100% sure but pretty sure. The LMC catalog has the overall dimensions for the various fuel tank sizes in the squarebody section, if anyone cares to doublecheck. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-19-2015, 02:22 PM | #22 | |
02-19-2015, 04:23 PM | #23 |
Does anybody know of a drop-in EFI sending unit for these 40 gal tanks? A high pressure unit for multiport?
What about ohm reading compatibility?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
02-19-2015, 07:37 PM | #24 |
All about them K’s
Don't know about a high pressure in tank unit but you could always use an external pump and a standard sending unit I would think.
02-19-2015, 10:10 PM | #25 |
yep, and that's what I'm trying to get away from.
