Old 11-11-2012, 12:10 AM   #1
67ctener
67ctener's Avatar
67c10 build
Day I brought it home after a lot of Craigslist searching. I could barely get it on the trailer, no springs front or rear and one tie rod haha
67ctener is offline   Reply With Quote
Old 11-11-2012, 12:21 AM   #2
67ctener
67ctener's Avatar
Re: 67c10 build
Frankenstien
Old 11-11-2012, 12:46 AM   #3
67c10rustbuket
67c10rustbuket's Avatar
Re: 67c10 build
Congrats! she is as colorful as mine
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 11-11-2012, 01:10 AM   #4
67ctener
67ctener's Avatar
Re: 67c10 build
Thanks, I think it may be a few trucks in one haha. Couldn't wait to tear it down and start workin on it
Old 11-11-2012, 01:12 AM   #5
67ctener
67ctener's Avatar
Re: 67c10 build
Can't fab so I got a c-notch from cpp
Old 11-11-2012, 01:15 AM   #6
67ctener
67ctener's Avatar
Re: 67c10 build
Old 11-11-2012, 02:03 AM   #7
67ctener
67ctener's Avatar
Re: 67c10 build
New Ece crossmember in place of the stock one. Very sweet, high hoop for pinion angle and exhaust cut outs. Very impressed with there products and service
Old 11-11-2012, 02:06 AM   #8
67ctener
67ctener's Avatar
Re: 67c10 build
Just about ready for sandblasting...
Old 11-11-2012, 09:46 AM   #9
rkintn_68
rkintn_68's Avatar
Re: 67c10 build
Looking Good !!!
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD
70 CHEVY C/10 LWB x 2 ----- SOLD
67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN "
Build thread :
http://67-72chevytrucks.com/vboard/s...15#post6826315
rkintn_68 is offline   Reply With Quote
Old 11-11-2012, 12:24 PM   #10
67ctener
67ctener's Avatar
Re: 67c10 build
Thanks, hoping joining the site will help push me along
Old 11-11-2012, 12:26 PM   #11
67ctener
67ctener's Avatar
Re: 67c10 build
After sandblasting
Old 11-11-2012, 12:27 PM   #12
67ctener
67ctener's Avatar
Re: 67c10 build
Old 11-11-2012, 12:31 PM   #13
67ctener
67ctener's Avatar
Re: 67c10 build
Just got it home from powdercoat. Put in my new trailing arms from Ece, my stock ones were bent up and twisted. It was Nice being able to start with something clean and like new
Old 11-11-2012, 12:34 PM   #14
67ctener
67ctener's Avatar
Re: 67c10 build
Front crossmember back in. Got all the hardware from my local Home Depot, great selection on grade 8 hardware
Old 11-11-2012, 03:03 PM   #15
67ctener
67ctener's Avatar
Re: 67c10 build
New raybestos upper and lower control arm shafts powdercoated
Old 11-11-2012, 03:08 PM   #16
67ctener
67ctener's Avatar
Re: 67c10 build
2" drop springs
Old 11-11-2012, 03:15 PM   #17
67ctener
67ctener's Avatar
Re: 67c10 build
6" rear drop springs, shock mount relocator brackets and adjustable pan hard bar from ece
Old 11-11-2012, 03:16 PM   #18
67ctener
67ctener's Avatar
Re: 67c10 build
Old 11-11-2012, 04:10 PM   #19
Xeen
Xeen's Avatar
Re: 67c10 build
Great start, I cant wait to see more.
What are your plans for brakes, are you doing Disc up front and Drums in the back?
Also out of curiosity since the truck is pieced together from a bunch of different trucks does the vin plate on the cab match the stamp on the frame, because depending on the state it can be a real pain to make it legal again if it doesnt.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 11-11-2012, 04:17 PM   #20
67ctener
67ctener's Avatar
Re: 67c10 build
Thanks, the vin actual does match withe the title, vin tag and frame. I've got pictures of the brakes I will upload
Old 11-11-2012, 04:21 PM   #21
67ctener
67ctener's Avatar
Re: 67c10 build
13" cpp big brake disk front. Pretty sweet kit, everything for the front came assembled. 2.5" drop spindles were raw cast though so I pulled it apart to powder coat the spindles. Only downfall is my stock 15s won't work as rollers cause they won't clear the brakes so it'll be camped out on jack stands for awhile
Old 11-11-2012, 04:25 PM   #22
67ctener
67ctener's Avatar
Re: 67c10 build
12" rears waiting for a rear end to go on
Old 11-11-2012, 04:28 PM   #23
67ctener
67ctener's Avatar
Re: 67c10 build
With suspension in at 4.5 in front on a 2.5" drop spindle and 2" drop spring set up for a sb. I may go big block and adjust the rear to match the front, maybe a 1" rear block setting it about 5/7
Old 11-11-2012, 04:34 PM   #24
Xeen
Xeen's Avatar
Re: 67c10 build
Yeah those big brake kits really like 16" or larger wheels.
It shouldnt be a problem though since more late model cars and trucks are comming from the factory with larger wheels and tires these days so the tires will be much less expensive than years past. Are you thinking about a 18" or larger wheel?
Old 11-11-2012, 04:37 PM   #25
67ctener
67ctener's Avatar
Re: 67c10 build
Yeah I would like to run 20s on it. 8.5 up front and 10s in the rear
