Old 11-16-2012, 04:43 PM   #1
not2oldchevy
Which block hugger headers aree you using?
Looks like I am going to have to use block hugger headers on my 5.3 AD with C4 front end. I have 3 sets of manifolds and C5 worked until I ran my brake lines now they are to close for my likeing. What is a good fitting brand to use?
not2oldchevy is offline   Reply With Quote
Old 11-16-2012, 07:42 PM   #2
clinebarger
Re: Which block hugger headers aree you using?
Why not just reroute the brake lines?
clinebarger is offline   Reply With Quote
Old 11-16-2012, 08:12 PM   #3
crazy longhorn
Fabricate till you "puke"
2nd that, but we all know that a pic is worth 1000 words crazyl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-16-2012, 10:55 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I used Sanderson CSLS1 shorties
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-17-2012, 12:20 PM   #5
not2oldchevy
Boxed frame with no other good way. Only way around is under the frame.
Old 11-18-2012, 08:48 PM   #6
71chevystep4x4
71chevystep4x4's Avatar
I used Hooker block huggers, They are a universal application header for no specific vehicle, with tight clearance set ups. Center dump, and they come out parallel and slightly pointed in at the top of the oil pan. Only about $240, I used them because I was concerned with the stock z-bar clutch linkage that I decided to stay with. They come very close to the back of the starter, but will work fine. I still am awaiting exhaust from there on out.
71chevystep4x4 is offline   Reply With Quote
Old 11-21-2012, 10:32 PM   #7
71chevystep4x4
Hooker #2312
Old 11-22-2012, 12:19 PM   #8
Shon
I will match that ebay price of $240 shipped if interested.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
