Old 11-19-2012, 06:49 PM   #1
lukes63chev
front coil springs question
i saw a set a lowering springs for 75, but my question is can i put 4 inch lowering springs with out droped spindles, i have a 63 c10 that im trying to lower. also if i cut 2 coils off the front how low would it sit and would the camber be way off
lukes63chev is offline   Reply With Quote
Old 11-20-2012, 08:55 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: front coil springs question
Hotchkis make a front lowering spring that is suppose to drop the front 4".
Cutting 2 complete coils is too much to allow for a proper front end alignment.
1-1/2 coils will get you approximately 3" of drop.
I highly suggest drop spindles and disc brakes.
Keith
Convert to disc brakes.
Old 11-20-2012, 06:40 PM   #3
lukes63chev
but with the alignment be ok with the hotkis springs
Old 11-20-2012, 06:44 PM   #4
lukes63chev
will the algnment be ok with the hotchkis springs
Old 11-20-2012, 06:51 PM   #5
LEEVON
LEEVON's Avatar
I would guess that yes it will align because there is alot of room to shim the UCA on these trucks, but you have to remember your ball joints will be at a high angle and you'll be close to riding on the bumpstops. You won't be happy with the ride, trust me. I'd save some jack for 2.5" spindles and cut one coil.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-20-2012, 06:57 PM   #6
lolife99
lolife99's Avatar
I have no idea.
I don't know how Hotchkis get this 4" drop number.
I've cut stock springs to achieve a 4" drop,... and when you jack up the front,... the spring will fall over in the spring pocket.
I still say a 3" drop spring is the MAX.
(my opinion)
Keith
Old 11-21-2012, 12:27 AM   #7
lukes63chev
well that will be good because i just want to lower the front a little so its not so dam high, also im going with 205 tires instead of 235, it will help a little. and im still in highschool and dont ahave a lot of money but thanks for the help
Old 11-21-2012, 12:40 AM   #8
kaycee
kaycee's Avatar
1 1/2 coil cut will give u 3" of drop,the 205 will not fill up you wheel well like the 235.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 11-22-2012, 01:50 AM   #9
lukes63chev
ya i dont care about that i just want to lower it.
chevy, spring, truck
