11-22-2012, 08:41 PM | #1 |
Is this 1" or 1 1/8" bore... my eyes suck!
Swapping out my master cylinder and putting in a disc/drum prop valve from a PO cluster bang and can't figure out the bore size of the MC. Where do you measure from? the lip, rubber surround... The sizes are so close I am getting nervous picking a size and ordering one. Any thoughts?
Appreciate the time! Weev-
Weev- Life's tough...... It's even tougher when your stupid - John Wayne |
11-22-2012, 09:45 PM | #2 |
Re: Is this 1" or 1 1/8" bore... my eyes suck!
Measure the inside bore.
11-23-2012, 11:23 AM | #3 |
Hey Weev,
Get a vernier or digital caliper, one of my favorite tools.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
11-23-2012, 12:13 PM | #4 |
nuttin like havin the right tool for the right job
i second the caliper vote
11-23-2012, 12:57 PM | #5 |
Ya I gotta pick one of those up! Should check this weekend with Black Friday deals.
Thanks guys Weev- Posted via Mobile Device
11-23-2012, 01:11 PM | #6 |
I'd guess a 1" bore. It looks like the lip is an 1/8" on either side so subtract a 1/4" off what you see.
Posted via Mobile Device |
11-23-2012, 04:32 PM | #7 |
I got my cheapy dial gauge from Harbor Freight for like $8
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
11-23-2012, 04:32 PM | #8 |
It looks like 1 1/8 in. to me.
11-23-2012, 05:26 PM | #9 |
While having the proper tool to measure with is best, there are ways to use a tape accurately.
A tape measure is handy, but much better suited to building a house than a truck or an airplane. The biggest problem is the zero hook at the end. It slides in and out for an inside or outside measurement. Again great when a circular saw is used but not in this or similar cases. To use a tape measure you need to remember the first inch is useless, period. Also the markings are not very uniform on less expensive tapes. So the simple way take a measurement is to "burn" the first inch and start measuring at the 1" graduation as I did in the reworked picture. Now by laying the tape up and trying to line up with the true bore and not the relief bevel it looks close to 1 1/8" (1.125"). If the number needs to be really close try a second confirming measurement further up the tape say starting about the 4" mark. Hope this helps and is a handy tip to remember at the used parts yard with a 10' pocket tape.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
11-23-2012, 05:41 PM | #10 | |
11-23-2012, 08:24 PM | #11 |
A guy with a truck
Are you running a booster or not? Generally speaking, the 1" is used for manual and 1.125" for power. Screwing this up can make a HUGE difference in pedal feel and braking ability.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-23-2012, 08:30 PM | #12 |
I have power brakes with a 9" booster.
