Old 12-03-2012, 01:24 PM   #1
tex_waco_usmc
Project Heaven in my 67!!!
Finally Found: E-brake lever and Spring for rear disc setup
Ok, so I bought the rear disc brake setup from CaptainFab a while back and have been looking for the rear disc caliper setup for a 76-78 Eldorado because in TX we have to have an emergency brake to be legal. I havent been able to locate any in wrecking yards and finding the spring and lever assembly is almost impossible (at least for me it was). I got the calipers at the local parts store brand new (I dont like using used parts for the braking system).
Now after some research I found a place that makes/sells the lever and spring. The place is called BlackBird Custom Trucks and they are out of Spokane, WA.
I am in no way affiliated with these guys at all, but I figured if I was looking then someone else might also be looking and might need these as well.
Here is a link straight to their products page. They are a little higher than what I was expecting, but at least I will be legal and everything will work properly.
http://www.blackbirdscustomtrucks.com/index21.html#4eb
Hope this helps someone out!
tex_waco_usmc is offline   Reply With Quote
Old 05-04-2013, 07:26 PM   #2
BigRed76
BigRed76's Avatar
Re: Finally Found: E-brake lever and Spring for rear disc setup
Did you get these calipers set up with rear discs? If so how well do they work?
I've read a lot of bad reviews about the e-brake not working very well on them...
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 05-04-2013, 08:14 PM   #3
Tinkermc
I have not yet but intend to ad rear disc to my 72sbss.
Tinkermc is offline   Reply With Quote
Old 05-05-2013, 10:40 AM   #4
sprint_9
sprint_9's Avatar
Make sure you take pictures.
sprint_9 is offline   Reply With Quote
Old 05-05-2013, 10:56 AM   #5
mr48chev
mr48chev's Avatar
That should help a lot of guys who buy the calipers from the parts house but don't get the levers or springs.
My ongoing truck projects:
Old 05-05-2013, 06:09 PM   #6
rcrahn
rcrahn's Avatar
Thanks for sharing.....I'm very interested in any pics you can show of these parts on the calipers. I'm in the same boat and this will really help. Thanks
rcrahn is offline   Reply With Quote
