Old 12-05-2012, 01:45 PM   #1
Adams74Chevy
Adams74Chevy's Avatar
NP203 making noise? or something else
I have noticed that on the few occasions I've had to drive my truck lately that it sounds like a clicking noise when it's in gear is coming from the transmission/transfer case area. It is steady clicking but faint compaired to my exhaust so it's a bit hard to hear. It does seem change in speed depending on rpms. Am I crazy in thinking it's something inside the transfer case it's a NP203 that was converted to part-time by a previous owner. Or could it be something in the transmission or the flywheel? I mainly hope I can either quickly and cheaply fix it or be able to put it off until the spring since they're saying this winter is going to dump a lot of snowaround here.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 12-05-2012, 07:28 PM   #2
LONGHAIR
Re: NP203 making noise? or something else
I would definitely look into it, especially on a converted case. There is a small "torrington" type thrust bearing installed as part of the conversion process with most of the kits. It can fail, especially if the PO has not kept up with the lube/maintenance. If it does fail, not only are there rogue parts running around in there, you lose the "spacing" that it was providing. This can lead to a gear "clashing" of the planetary ring and the out-put for the chain-drive to the front shaft.
It is definitely worth opening it up, just for the peace of mind. It's only an hour or so to open it up.....and put it back, if there is nothing wrong. Could be very costly if it fails more spectacularly.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-06-2012, 09:47 AM   #3
Adams74Chevy
I do need to pull it anyways to replace the output shaft seal on the transmission. Sounds like worse case I'll pull the NP203 out of my parts truck and throw it in.
