Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-07-2012, 06:23 PM   #1
Car'n'Guitars
Car'n'Guitars's Avatar
Question 1988 Blazer
What transfer cases were used in the 1988 Blazers with the th700r4 transmissions?
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 12-15-2012, 12:12 PM   #2
BarryB
BarryB's Avatar
Re: 1988 Blazer
If you were looking for #'s I can't tell you. I do know some had the awd case, but I believe those were in the olds bravada, and the Sy , and Ty turbo charged versions of the S15 and Jimmy.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 12-15-2012, 03:17 PM   #3
Car'n'Guitars
Re: 1988 Blazer
Yeah I was hoping someone could give me the transfer case models.
Old 12-17-2012, 12:24 AM   #4
BarryB
BarryB's Avatar
Re: 1988 Blazer
I love this site but for more technical info, you might check over on s10forum.com seeing this section of the site doesn't get alot of traffic.
Two rules in life.
Old 01-05-2013, 05:05 PM   #5
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 1988 Blazer
I'm going to assume you are talking about the full-size Blazers, and they came with the np241.
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 01-05-2013, 05:23 PM   #6
Car'n'Guitars
Re: 1988 Blazer
No I'm not talking about the full-size Blazers, but I did look and seen it is a np241 are these any good?
Old 01-05-2013, 05:31 PM   #7
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 1988 Blazer
OOps didn't realize this was in the s10 section, don't know how I got there. The np241 is a pretty good transfer case, it's no np205, but it is based of the np208 and as a result its shift on the fly. A buddy of mine has one in his 89 full-size, and it works great.
Old 01-05-2013, 05:36 PM   #8
Car'n'Guitars
Re: 1988 Blazer
Do you know whether or not it's better than the np208?
Old 01-05-2013, 05:37 PM   #9
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 1988 Blazer
Although, now that I think about it. You sure it was a np241 or was it a 231? I don't think the 241 was available in the S-series, too big I think. The 231 isn't a bad t-case, but it's good for an s-series or smaller. Wouldn't wanna put them in anything bigger.
Old 01-05-2013, 05:41 PM   #10
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 1988 Blazer
Depends what you're using it for? The 241 has electronic controls, the 208 is strictly mechanical. I would go with the 208 myself, it's more robust.
Old 01-05-2013, 05:42 PM   #11
Car'n'Guitars
Re: 1988 Blazer
I'm pretty positive it is a np241, but I will check again. But if indeed it is a np241 is it worth keeping around as a backup or anything?
Old 01-05-2013, 05:43 PM   #12
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 1988 Blazer
What are you looking to do with the t-case, replace a junk one or use it in something else?
Old 01-05-2013, 05:44 PM   #13
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 1988 Blazer
Yup, It's worth keeping around.
Old 01-05-2013, 05:50 PM   #14
Car'n'Guitars
Re: 1988 Blazer
It's just sitting in the garage collecting dust, and if it was stronger than the np208 I would look into swapping it but if its about the same I wont, but I will keep it around just in case or a future project or something.
Old 01-05-2013, 06:32 PM   #15
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 1988 Blazer
Just make sure that what ever it is you want to put it in, that they are similar in style. Meaning they drop on the same side (drivers or passenger) and the transmission is the same, and that they are both manual or electronic shift. If it's for your 85 k10 then the S10 transfer case won't work. The K10 is passenger side t-case and s10's are drive side t-cases.
