Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-07-2012, 10:04 PM   #1
brans72
compressor lines let see them
Looking for ideas on redo my hard line compressor lines in my garage and wanna see what you guys have used and how you run them. Please list pipe size and dryer etc your using in piping. Right now I have some leaks in my 3/4 black pipe ( I threaded it all by hand 3 yrs ago) and was never that happy with the install but on budget that is tight as s%*t. So any advice on doe's and do not. Also best ways to keep water out besides drain tank and drips. Thanks in advance guys. Brandon
brans72 is offline   Reply With Quote
Old 12-08-2012, 11:32 AM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: compressor lines let see them
There’s a good all around thread HERE on plumbing (see post #5 especially).
Another good thread with a routing picture is HERE. Check post #15.
There’s a lot of good info on water control on that thread as well.
For water control, I like theastronaut’s fridge cooler on this thread (post #18).
I'm sure the guys will pipe in soon (pun intended ) with their own favorite setups.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 12-08-2012, 02:01 PM   #3
russgoodman
russgoodman's Avatar
I've been working on mine lately as well, hopefully I can finish it up tomorrow. I used black pipe but only 1/2". I will have a T at that last unfinished pipe with one side going through another ball valve, then to my motorgard filter and then a QC3 drier. I will shut that valve and only use that line for painting.
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554
2008 GMC Sierra Denali - 6.2L AWD - my daily
2011 Ford Flex Limited - Ecoboost AWD - wife's daily
1987 Buick Regal Turbo T - 63K miles - Strip/Street car
1965 Ford Mustang Coupe - 289, c4, 53K miles
russgoodman is offline   Reply With Quote
Old 12-18-2012, 03:13 PM   #4
Gus350
68 C 10
Gus350's Avatar
A couple I have saved.Name:  aaa.jpg
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 12-19-2012, 01:53 PM   #5
arturo7
arturo7's Avatar
Can I assume that the elaborate pipe runs are meant to aid condensation?
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 12-19-2012, 02:32 PM   #6
ERASER5
ERASER5's Avatar
You can.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-21-2012, 10:13 PM   #7
_Ogre
_Ogre's Avatar
1/2'' copper thru out
shop air compressor timer
Old 12-25-2012, 10:52 PM   #8
sleepertruck72
sleepertruck72's Avatar
Nice setups ! I was planning on using some 1/2" SCH40 PVC ... anyone using PVC ?
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 12-26-2012, 12:05 AM   #9
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
you guys with the back and forth pipe runs may want to have the air run through there before it gets to the compressor tank. I just built an aftercooler for my compressor that does this. It cools the air right as it exits the compressor. This removes moisture before it gets to the tank and at the same time, allows more air to be stored in the tank. At the inlet of my cooler, its too hot to hold your hand on and on the outlet its comfortable to touch or lukewarm.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-26-2012, 12:46 AM   #10
Number21
Number21's Avatar
DO NOT use PVC!! PVC is NOT safe for air. PVC gets brittle with time, and especially with exposure to light. One day it will blow up and kill somebody. PVC manufacturers tell you not to use it with air and it's even against OSHA rules.
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 12-28-2012, 10:24 PM   #11
RanchFlyer
PVC is a waiting grenade. It will rupture at a glue joint, then resulting movement in the tube will cause it to splinter into flying shards of plastic. A machine shop I used to business with experienced this, after 3 years of me warning them. Within a couple of months they were all switched to Legris transair, which is now a Parker product. My suggestion is find a local contractor installing transair or IR simplair, and see if you can buy any excess. Sometimes when I used to bid a big job, we would sell off the extra fittings and tube, at cost or less. Nobody wants to inventory fittings. That's my experience anyways.
RanchFlyer is offline   Reply With Quote
Old 12-30-2012, 03:40 PM   #12
sleepertruck72
Ouch !!! Thanks for the input guys, I had no idea !
72 C20 Longbed
05 1500 Z71
Old 01-08-2013, 01:06 AM   #13
Vintage Windmills
Vintage 4x4s
Here is the compressor I just redid. Added an aftercooler before the air enters the tank. To the lower right of it is a filter with clear bowl. This serves as a water trap. I can let this drip and not let the tank bleed down since there is a check valve after this. The cooling is improved by mounting where the motor fan draws air through.
Old 01-08-2013, 02:06 AM   #14
DesertCat
DesertCat's Avatar
Most of the ideas you will hear about are more complex than they need to be.
Not the first time I have posted this on this site:
every body shop I worked at had a large diameter standpipe (like 4") right off the compressor that went to the ceiling. A smaller diameter pipe tee'd off the top and ran downhill at least 20 feet with about a 4" per foot drop (angled downhill), which tee'd into near the bottom of another 4" standpipe. The final airline takeoff was well above that tee.
The reason? Lower velocity in the large diameter standpipes, high velocity in the smaller downhill run. Finally the moisture crashing into the second standpipe (again low velocity so the droplets tend to fall out of the airstream.
This was all done with black steel/iron pipe for cooling. Petcocks at the botton of the standpipes and a simple water trap where you hooked up your air hose.
I always installed a mini trap on my guns... very rarely had a problem.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
