Old 12-12-2012, 01:14 PM   #1
ScottG
Another 700r4 question
So, I'm now to the point of swapping speedo gears on my 700R4. My question is, do I need to put back the "sleeve" that was on the shaft that butts up against the gear? It's about 3 1/2-4 inches long. I can't find anything that talks about it.
'67 C20 LBW
ScottG is offline   Reply With Quote
Old 12-12-2012, 01:15 PM   #2
ScottG
Re: Another 700r4 question
I guess I should include I'm swapping from electric to mechanical speedo gears.
'67 C20 LBW
Old 12-12-2012, 07:24 PM   #3
shortbed70
shortbed70's Avatar
I don't remember a sleeve when I did mine from elect to mech... I would say if the gear fits on the shaft tight then I say no. It would help if I knew exactly what the part was.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-12-2012, 07:59 PM   #4
clinebarger
If the slip yoke has a "weep hole" in it....You need the sleeve.
If not.....Leave it off.
The weep hole relieves pressure buildup caused by the yoke moving back an forth as the vehicle passes over bumps.
If you have a weep hole & need to reinstall the sleeve....Replace the O-ring GM P/N 3764601
clinebarger is offline   Reply With Quote
Old 12-13-2012, 12:36 AM   #5
shortbed70
shortbed70's Avatar
AH HAA that's where that drip is coming from... Forgot about the wheep hole. So can I just change yokes on mine since it didn't have the sleeve?
Troy
Big Red Dog build
Old 12-13-2012, 11:35 AM   #6
ScottG
that answers my question, thanks!!
'67 C20 LBW
Old 12-13-2012, 07:59 PM   #7
clinebarger
Take the yoke off the drive shaft, Drill & tap the hole to 10-32, Cut down a 10-32 screw to about 3/8", Put some Red Loctite on it & run it in, Let sit for 24 hours to let the Loctite cure, This is a permanent fix, & beats buying a $100 Yoke.
Old 12-13-2012, 11:46 PM   #8
shortbed70
shortbed70's Avatar
Thanks.
Troy
Big Red Dog build
Old 12-20-2012, 12:42 PM   #9
ScottG
driveline shop is installing a new yoke, and he's gonna weld up the weep hole. New center support and joints as well. I think I'm going to snap some pics of the conversion and post them so people can get a visual of what's needed to do this swap.
'67 C20 LBW
700r4, 700r4 swap
