Need rear door hinge.
I was changing out all hinge pins and broke one part off trying to get old pin out. Can reweld maybe but wanted to check to see if anyone had done thanks
Posted via Mobile Device Posted via Mobile Device Last edited by vectorit; 12-13-2012 at 06:32 PM. Reason: WTB |
What?
Re: Need rear door hinge.
I have heard others use the door hinge pin used for the front door.
Are you saying that you busted off the pin inside the hinge? The hinge itself is not reproduced, and is a salvage part.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
No I busted off one of the holes the pin goes thur. And still didn't get it out. So if anyone has a salvage one let me know. Otherwise I will try to get rest of pin out and weld it up.
Posted via Mobile Device |
The Older Generation
Check on the Burb/Blazer parts board here: http://67-72chevytrucks.com/vboard/f...prune=-1&f=199 Technically you aren't supposed to post a wanted to buy since you are not a paid member but you can surf the parts board and see if someone is parting out a burb. If you see one for sale you can purchase it though. LockDoc
