12-16-2012, 05:44 PM | #1 |
Dana 60 Swap
I have a good Dana 60 front out of my '93 Cummins I'd like to stick under my '72 K20. The only problem that I can see is that the dodge steering arm raises up instead of drops down. This will make my tie rod angle off. Did Chevy use a dropped steering arm that would fit the dodge axle?
12-18-2012, 02:12 AM | #2 |
Collector of Projects
Re: Dana 60 Swap
Dont quote me, but I remember somethign about the Dodge spring perches being 1" wider. The other thing I read somewhere is there is a Dana 51 one out there. I looks like a D60, but has some oddball internals.
12-18-2012, 04:41 AM | #3 |
Re: Dana 60 Swap
Ford used a dana 50 in the 99 up super duty f250 its basicly a dana 60 housing with dana 44 diff in it.
12-18-2012, 09:10 PM | #4 |
Re: Dana 60 Swap
I definitely have a Dana 60. I will have to look a little closer at the width (I thought they were within 3/4").
What steering arm fits? |
12-18-2012, 11:58 PM | #5 |
Currently Blazerless
Re: Dana 60 Swap
You can use the Chevy Dana 60 arm on your Dodge axle..it will bolt right on. I used the Dodge arm on my Chevy 60 and it worked great with a 4" lift..it had to be tapered for the Chevy TRE from the opposite side but its well worth it if your running a lift. You will also have 1/2" wheel studs on the Dodge 60 versus 9/16" on the GM version...thats a simple fix by just using the GM 9/16" studs on your Dodge axle...knurl size is the same between the two.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
12-19-2012, 12:37 AM | #6 | |
Re: Dana 60 Swap
There is a Dana 61 that cam in the 89 dodges. its almost the same as the 60 but had 3.07 gears that were not available in 60s Ryan |
12-22-2012, 12:09 AM | #7 | |
Re: Dana 60 Swap
So where can I get a Chevy arm? Anybody want to trade? |
12-22-2012, 12:14 AM | #8 |
Re: Dana 60 Swap
ill look through the parts bin. i may have one laying around from my jeep.
Ryan |
