Shoulder Belts
So my friend loves the Suburban, she says it rides smooth and loves when I do donuts and go off road.
![]() But the passenger side lap belt is broken (for some reason, the car has 4 different seat belts, and this one is from a Ford) So I was wondering if I could fit in some Shoulder/Lap belts. I know there are some threaded holes on the side near the tops of the seats, so I don't see how it couldn't work. I've seen they have a factory option, but I'm not going to try hunting those down. I've only seen one other Suburban in Western Washington and none in the junkyards. I suppose it would be best to look for some from another truck. What do you guys think? |
Re: Shoulder Belts
I took some out of a PT Cruiser when I took the leather heated seats from it. I used the threaded holes in the B pillar for the upper mount, and made a bracket to mount the retracting part to the floor with the stock mounting bolt and hole down there as well. I love the fit and function of these belts, and they mate up perfect to the buckles on the seats, since they were made to be together anyway. They are also height-adjustable.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
#3 | |
Re: Shoulder Belts
Re: Shoulder Belts
I will take and post some pics tomorrow. The seats fit great, but I had to modify the brackets a little, but that is to be expected. The seats are perforated leather and have the heater switches mounted to the sides if the seat. They also have a fold down armrest. Best thing of all was that I got the 2 front seats, the back seat, and seat belts for under $100 from Pick-n-Pull
Re: Shoulder Belts
Thanks, I'll be looking forward to it. I'm excited about getting the suburban running, but also trying to make it act and feel like a daily driver as much as possible.
Re: Shoulder Belts
I bought a pair of shoulder belts from JC Whitney (I won't make that mistake again). The one problem I had is that the retractor would not release unless it was positioned straight up. I had to create a bracket using some angle iron to get them to work. I would have sent them back, but I needed the shoulder belts installed quickly (ex-wife and child seat issues). So, should you go to buy some or harvest some, pay attention to the position the retractor needs to be in for them the belt to release and thereby allow you to pull the belt out.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
#7 | |
Re: Shoulder Belts
