Robert Olson Transport
![]() Join Date: Oct 2002
Diesel guys
here in the northeast it gets cold this time of year. My CUCV doesn't seem to like starting . Im changing out the fuel filter and I was thinking about a block heater.. What are you guys running and how do you install it? Im really not thrilled with the ebay ones that want you to drop out a freeze out plug.. anyone have any ideas or comments? part numbers and distributors?
Re: Diesel guys
I have one that goes inline the lower radiator hose on my gas truck my understanding is that the freeze plug ones are the best though but I think those are all opinions
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
Certified Pud Puller
Re: Diesel guys
The universal one that goes in the lower radiator hose would be the easiest. You can get one pretty cheap on amazon.
1997 Silverado extended cab- mpfi conversion, 22" kmc's 1983 C10- some assembly required 99.5 F250 Super Duty 7.3 5" straight pipe, wicked wheel, ts tuner, ccv mod, 4" lift 315/75/16s |
Re: Diesel guys
The purpose of a block heater is to do exactly that, those radiator ones are a waste of time & electric. Your truck should of came from the factory with one. I would search around for a 110 plug under the hood & rad support.
Re: Diesel guys
dont have a diesel but it shure is nice haveing heat right away
http://www.tractorsupply.com/magnetic-heater-0191958 got this heater on the oil pan. it heats the hole engine up.
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker. |
Re: Diesel guys
If u are going to do it do it right and get a good 1500 watt freeze plug type. Put it in the middle plug on drivers side and plug it in on a timer or a switch so it comes on about 90 before u start. Should run about 100 bycks. Puting it in is ez drain coolent out knock plug so the ti turns 90 degress out and grab with plyers and boilt in the heater. The oil heaters are not as good do to the fact that it will not heat the hole block well
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
Junior Member
![]() Join Date: Dec 2011
Re: Diesel guys
It is my personal preference to run a block heater and an oil pan heater in cold weather.
Both heaters will help your engine starting problem independantly of each other. Keeping your cooling water warm will help the fuel ignite when injected. Keeping your oil warm will help the engine spin over faster in cold weather and will also provide better oil flow and thus increased lubrication during the crucial moments following start-up. By using both of these heaters together your engine will start like it was a warm summer day and will be fully lubricated and protected upon startup. This may sound like overkill; but at work we keep our 9500HP Generators warmed up with the water and oil both at 160F so we can go from stopped to 100% load in only 30 seconds without damaging the equipment.
If it wasn't for the last minute, nothing would ever get done. 1953 3800 - SRW C&C Dump - 216/SM420 1985 K30 Scottsdale - SRW - 6.2/SM465/NP205 (Sold) |
Re: Diesel guys
If you can plumb in a circulating heater,it will work WAY better than just a regular block heater.All the block heater does is heat up a small area of coolant,but the circulating heater will warm up the entire block! Trust me on this one,it gets cold up here!! I have circulating heaters on anything that's not in the heated shop& they start great.When hooking up the circulating heater,make sure your on the engine side of thermostat & the heater is below the water level & you should be fine...
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" ![]() |
Re: Diesel guys
Every 6.2 has a freeze plug heater from the factory. Works well. You don 't want a tank heater, no interest in getting that huge radiator warm.
Your truck will start without them, make sure you have good glows, 60G's on a separate switch and give them a few extra seconds before the crank. Make sure you're running a winter fuel blend. I've heard of people installing a Cummins intake heater grid with great results.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
Moderator
![]() Join Date: Oct 2008
Re: Diesel guys
If all 8 glow plugs are operating properly she will crank right up.
Get a freeze plug heater, if you don't already have one, and install it on the LH side in a center plug. If the freeze plug heater is missing the cord (my M1008 was) you can buy one of those separately. http://www.jegs.com/i/JEGS-Performan...rentProductId= Want to double the warmup speed? Add one to the RH side. Tank heaters are easy to install but are only effective when both of the heater hoses both run to the engine. At -10F the block will be very close to operating temp 45 minutes after you plug it in. The winter oil should circulate just fine from the radiated heat off the 180`F block. Pan heaters used to burn the oil film to the sheet metal above the bulk of the oil. I can live without extra carbon in my oil.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#11 | |
Re: Diesel guys
Re: Diesel guys
I have one stock in my truck and its located on the bottom drivers side of the block
Bear the lower powerstwaring mount and by the oil pan. Only thing is I've yet to use it this winter. Reason being is I swapped my glow plugs out to be manual rather than automatic and I also put in new glow plugs. (Acdelco 60G) I just flip the switch for about 30-45 seconds turn over the starter and she fires right up. My coldest start this year was 21degs F. Posted via Mobile Device
Zaccaglin 1998 Chevrolet C1500 Ext. Cab 350 Former Rig: 1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208 |
#13 |
GoatLube Experss
![]() Join Date: Oct 2009
Re: Diesel guys
the freeze plug type is your best bet but with good glow plug's it should start right up, when it's real cold you may have to cycle em a couple of time's. I start'd all my HMWWV's and SRATS every morn'n with no problems last winter , (some morn'ns were 10 below) with just glow plug's.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#14 | |
Re: Diesel guys
#15 |
Re: Diesel guys
ok next question last night I put the heater I bought on the block ( bottom of the oil pan and left it on all night.. it was around freezing out maybe as low as 30.. today I started the truck it was difficult to start, smoked like a fiend and the valve that had cleared itself up sounded like it was sticking again for a while. I did not move the truck.. Am I going to be better off with the one that hooks in the lower hose? Am I supposed to be leaving the thing plugged in all night or should I be plugging it in for a half hour in the AM or something before I use the truck? these diesels are such a pain in the butt !!
#16 |
Re: Diesel guys
Old rusty,if you just used the magnetic oil pan heater and no coolant heater it's probably not enough to warm your truck.Make sure your glow plugs are all working good too,that will make a big difference too. I would suggest looking on the diesel forum,those guys are very helpful when it comes to 6.2s. Back to the coolant heaters,that's why I like the circulating type,only needs plugged in a couple hours even in -20c weather,the block heater will need more time,especially if the engine is cold when you plug it in.
#17 |
Re: Diesel guys
Also should mention too,what weight of engine oil are you running too,something like a 0-30 or similar is good for cooler weather.
#18 |
Re: Diesel guys
The oil is sitting in the pan. Not warming the engine. It helps cold starts by getting your Iol temp to spec quicker reducing wear. If you get the water hot it will help it start a lil and reduce warm up time and wear.
I would agree that your glow plugs Prob need to be replaced and switched. The 6.2 I just pulled out of my k5 has a plug block heater. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#19 |
Re: Diesel guys
Gave you the wrong address,it's the diesel place ,not diesel forum...
#20 |
Re: Diesel guys
the plugs in my 6.2 are going already have one dead in drivers bank. but i have them ona switch and leve them on a little longer and she has always started even with some nasty nor easters that we get hear.
#21 |
Re: Diesel guys
Sounds like you have a dead glow plug or two. That cold cylinder will make it run ruff and even give a knocking sound. You may also need a new controller. It may not be allowing enough glow time. They go bad in different ways. Does the truck crank slow,like the batteries are weak? cold motor will crank like that with not enough pre-heat.
Does your Blazer have the freeze plug with heater connection? Those are the best way to go. That way GM designed them to start. I have both 6.2s and 6.5TDs and it's been a rare time I've plugged in to heat. The glow plug controller won't let the plugs cycle long at all if you do it a second time or more,if the plugs are heating much at all. On my 6.5TD one cycle doesn't seem to be enough. I'm sure I have a dead plug or two (or the dang wire keeps coming off). For whatever reason,that controller gives a complete second cycle and she comes to life like it's 90 out. Check that your wires are connecting good on the plugs and also check/clean any corrosion. I cut the plastic off and crimp the connectors to make them tighter,too. Here are some good sites: www.thedieselpage.com www.thedieselplace.com My be something here: http://www.thedieselpage.com/t&rguide.htm
#22 |
Re: Diesel guys
I have ordered a set of glow plugs for the truck. The controller is brand new as is the card.I will replace those this week..im running the Shell Rotellat 15W40 oil as per a suggestion by the truck parts store.. I was also told Delvac is good.. I was told to run some Lucas in there too but that is a way off as id have to change the filter
#23 | |
Moderator
Re: Diesel guys
#24 |
Re: Diesel guys
It's just not all that technical. If your glow plugs are working right your truck will start in the cold with whatever oil you have and w/o plugging it in. Once you get into single digits the big issue is fuel gelling and there's nothing you can really do about that. That's the only time I use a fuel conditioner and I keep my tank full. The heater can help,but does nothing for the fuel in the tank and lines.
#25 |
Moderator
Re: Diesel guys
The Jetta and all 3 trucks all start with no hiccups at -30F without plugging them in. The truck engines and even my A5 TDI Jetta (with no freeze plugs) have OEM coolant heaters but I almost never use them. I make sure the glows are in good shape and the GMC has winter oil.
BTW bad glow plugs will kill the CUCV glow plug card pretty quick.
