Old 12-28-2012, 01:29 PM   #1
spencer_41188
spencer_41188's Avatar
wiper motor
it seems to me me i have no luck with the wiper motor but i tried 4 diffrent motors and they all work the same speed and they stop where they are when i turn them off
is there a way to fix them so they reset to the bottom and speed them up
is there faster motors out of a diffrent model or year that uses the same bolt pattern that i can wire in
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
Old 12-28-2012, 08:31 PM   #2
ray_mcavoy
Re: wiper motor
The fact that you've tried 4 different motors and can only get them to work on one speed sounds to me like you are probably dealing with a switch or wiring problem.
Not returning to the parked position when switched off might also be a wiring problem. There is a "parking switch" mounted in the gearbox portion of the motor. If I remember correctly, the 1978-up permanent magnet wiper motors have a separate 2-wire plug that connects to that parking switch. So make sure the terminals in that connector are making good contact and that the wires aren't damaged.
I'm not aware of any other wiper motors that will be a direct bolt-in swap. However, the originals are pretty quick when they're working correctly. What slows them down is usually things like old worn out brushes in the motor, old dried out grease in the gearbox and linkage pivot points, and sometimes excess resistance in the wiring due to a bad switch and/or loose/dirty/corroded connections.
ray_mcavoy is offline   Reply With Quote
Old 12-29-2012, 03:49 AM   #3
spencer_41188
Re: wiper motor
well i had a 87 befor i got this 88 and the only think that has not change is the collum because the 88 was an auto setup with no motor or trans and i had the nv4500 and the 205 sitting around
anyway the work but there slow and dont return
ill probe the return wireing at the top of the motor see whats going on might have to clean the contacts
the 4 motors i tryed where junk yard pulls so it could be a factor
road salt sucks
Old 12-29-2012, 04:13 PM   #4
zaccaglin
zaccaglin's Avatar
Re: wiper motor
There is also a wiper motor delay controller located on the bottom side of the steering Colum under the dash. It has a large heatsink on it. Mine has failed so I only have two speeds for my wipers (on & off). I found that put the hard way by swapping motors myself too.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 12-31-2012, 12:33 AM   #5
spencer_41188
Re: wiper motor
oh so thats what that was i never had one on the 87 but the 88 had it i took it out thinking wtf is this but i did save it ... ill put it back in and see what it dose lol
Old 12-31-2012, 08:10 PM   #6
wraprail
wraprail's Avatar
Re: wiper motor
Spell check is your friend.
wraprail is offline   Reply With Quote
Old 01-01-2013, 12:40 AM   #7
zaccaglin
zaccaglin's Avatar
Re: wiper motor
Let me know if that works for ya. Funny your 87 didn't have it. My 85 does.
Zaccaglin
Former Rig:
