12-29-2012, 04:34 PM | #1 |
1ton upgread parts?
Want to know what guys are doing for 1ton parts to upgread like brakes and steering parts
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
12-29-2012, 07:27 PM | #2 |
Re: 1ton upgread parts?
Upgraded steering components like these from offroaddesign, alot of off roaders convert the rear to disc brakes.
http://offroaddesign.com/catalog/HDsteeringlinkage.htm http://offroaddesign.com/catalog.htm
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
12-29-2012, 09:42 PM | #3 |
yeah id like a set of brake lines that goes from the master to te prop. valve near the rad. the twisted ones. mines are surface rusted and i think they are 1/4 on 1 ton .
12-30-2012, 01:26 AM | #4 |
i like offroad.com some good stuff. does any one know of a rear dixk kit with ebrake? mass state inspection calls for it. also what about a posie unit for the d60? not a locker as she is a dd. any sujustion?
12-30-2012, 01:47 AM | #5 |
I have the early 80s Cadillac rear calipers on a homemade bracket on the 14 bolt full floater in my K5. The Idea was to have a parking brake. The Cadilac Calipers are basically the smaller Metric GM Calipers. So I used a rotor off of a 3/4 ton dodge front axle from the 80s because it was thinner than the Chevy stuff.The Hydraulic brakes work fine but the parking brake isn't worth a wooden nickle. Thought I'd fling that out there to keep someone from making the same mistake I made ten years ago.
One Change that made the biggest difference in the brake feel was putting on a set of steel braided lines instead of the stock rubber lines 14 bolt rears were used for a long time until the move to the AAM axles. Could probably move the spring pads on an axle from a 3/4 ton chevy from the early 2000s that came from gm with disks and a parking brake. I looked at doing this back when I did the rear brake swap on my k5 but the early 2000's stuff was new and expensive then. |
12-30-2012, 02:10 AM | #6 |
thanks for the heads up on the caddy rears. i do want to do the braided lines and switch to stainless any way. as for the rear swaps i cant weld....yet lol
12-30-2012, 04:08 AM | #7 |
where do i find braided brake lines for my dually? i have an 83
12-30-2012, 01:43 PM | #8 |
12-30-2012, 03:53 PM | #9 | |
I confirmed this over the weekend doing a rear brake job on my fathers 2001 3/4 ton pickup with a 14 bolt rear. It has massive 13" rear rotors and the calipers are literally twice the size of the little D52's. This is the setup really needed for a rear disc swap on a heavy duty truck. Otherwise I'll stick to my drums. I agree, swapping the entire rear and relocating the spring and shock mounts would be the easiest way to do it if the brakes can't be adapted to the older 14 bolt rears. To add, your rear e-brake discs won't have the holding power that a drum setup has, which is why it's not working that well for you. That's very typical of an e-brake that uses the rear disc pads. The old caddy calipers were unique that way, as well as your early rear disc cars like the 3rd and 4th gen F bodies up through 1997, they just didn't work all that well. That's why GM converted all their rear disc cars to an internal drum e-brake setup that rides inside the disc. But they are still a popular swap because they are so easy to adapt on older vehicles. Last edited by Firebirdjones; 12-30-2012 at 03:59 PM. |
12-30-2012, 04:30 PM | #10 |
Great resource for rear brake upgrades: http://www.tsmmfg.com/
I just scored a set of the big bore rear e-brake calipers from a '76 Eldorado, probably going to get their kit for my '93 10.5" 14 Bolt that I'm building for my '83.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
