12-30-2012, 12:28 PM | #1 |
Upgraded fuel tank selector valve???
I am in the process of installing a 383 in my 87 R10 pickup. Keeping the tbi system. Fuel pressure is being bumped up and I have been told it would be a good idea to replace my fuel tank selector valve with one that can handle the extra fuel pressure. Anybody else have to do this?
Posted via Mobile Device |
12-31-2012, 01:19 AM | #2 |
Re: Upgraded fuel tank selector valve???
Considering the stock fuel pressure is between 9-11 psi, generally speaking. Unless you are going to 40+ psi, I would think the valve will work just fine. I would be more worried about consistent fuel pressure. Which an aftermarket regulator would solve that problem.
12-31-2012, 10:43 PM | #3 | |
http://products.pollakaftermarket.co...-valve/42-159? Happy New Year //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
12-31-2012, 10:57 PM | #4 |
So this would be a direct replacement?
12-31-2012, 11:12 PM | #5 |
Yes, this as close to OE replacement, but minor modifications may be required to fuel line hoses and wiring. Get a complete kit with pigtail plug.
//RF
12-31-2012, 11:16 PM | #6 |
The switch in the cab will remain the same though right? The kit I saw came with a pigtail and a toggle switch but I would rather keep the in cab switch stock. Also, do you think this will be necessary? I am only planning to run the system at 18 psi and replacing the stock injectors with a set of the higher flowing police car injectors.
12-31-2012, 11:36 PM | #7 | |
