Old 12-30-2012, 08:58 PM   #1
weever82
weever82's Avatar
Help with m/c, brake line install on my 69!
Well... most of you know that I am a noob and it is showing right now... lol
Anyone remember the hack job I previously posted without the prop valve up front and it was out back by the rear tires..
Anyways, I ordered a CPP m/c w/ disc/drum prop valve and all new ss brake lines.
The two piece rear axle was easy, the long one that runs of the frame was pretty easy (got rid of valve) and even the ones across the front crossmember and front tires were easy... now heres the question...
I also hooked up the m/c but the two lines from the m/c to the lines on the frame... I can't figure out for the life of me how they lay on the frame and mount up...
Someone said that my brake lines were ran on the outside of the frame and now they are to be on the inside?
Also what are these two baby lines and bracket for??
Any help would be greatly appreciated. Again, thanks.
Weev-
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 12-30-2012, 09:45 PM   #2
69GWC
Re: Help with m/c, brake line install on my 69!
I cant help on your question, but where did you get the parts from? I need to do the same thing.
69GWC is offline   Reply With Quote
Old 12-30-2012, 10:18 PM   #3
Bhelton
Bhelton's Avatar
Those 2 baby lines and bracket is for mounting the proportioning valve sideways. I'll see if i have a pic of it and post it
Bhelton is offline   Reply With Quote
Old 12-30-2012, 10:26 PM   #4
M.Lowrie
This is what it looks like to have it mounted underneath the master cylinder using that bracket and those 2 lines.
M.Lowrie is offline   Reply With Quote
Old 12-30-2012, 10:29 PM   #5
Bhelton
Bhelton's Avatar
I went and got u a pic of bracket installed
Old 12-31-2012, 01:56 AM   #6
weever82
weever82's Avatar
Thanks for the pics guys! I see it now but my chrome prop valve when I lay it sideways... the holes don't match up with the bracket. Also one line looks like it would somewhat match up but the other one is still way off. Gonna call CPP in the AM and see what they had to say.
Weev-
Weev-
Old 12-31-2012, 01:58 AM   #7
weever82
weever82's Avatar
Ordered the wjole front line kit from CPP as well as the m/c and prop valve from CPP. The rear axle lines and line that lays across the whole frame was from inline tube.
Weev-
Weev-
