12-31-2012, 12:21 AM | #1 |
how did you route your exhaust?
looking for some ideas on how to run my exhaust, im doing dual 3" header back exhaust with a H pipe. how did y'all run your exhaust?
Tyler ------------------------------------------------------ 1980 2wd blazer 1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276 1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784 |
12-31-2012, 12:42 AM | #2 |
Re: how did you route your exhaust?
i got a crew 4x4 but it might help
cant help ya with over the axle but it shouldnt be that hard
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker. |
12-31-2012, 03:11 AM | #3 |
Got a flowtech exhaust kit for my truck and ran it as intended till the mufflers. Right after the mufflers I put the tail pipes on, it dumps right before the axles, instead of over and behind the axles.
1981 K10 Scottsdale
305 ci | TH350 | NP208 | 60k miles |
12-31-2012, 06:48 AM | #4 |
12-31-2012, 11:31 AM | #5 |
I run dual 3" on my pickup. It's all custom bent but it's running as an original would, around the rear spare tire (which is a full size 9.5x16.5) and exit out the sides behind the rear leaf spring hangers.
It's tight but it can be done if you find a competent shop. Last edited by Firebirdjones; 12-31-2012 at 11:37 AM. |
12-31-2012, 12:23 PM | #6 |
2.5" will be plenty if you're putting it on your vortec headed 350....and cheaper. 3" is easy to do, i had full 3" on a 79swb c10, straight out the back. it was way overkill for what the little 355 needed. rattled the cab pretty good, even with the h-pipe. take it too a good shop, someone who has been bending pipe for years can generally do anything you want them to.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
01-01-2013, 01:28 PM | #7 |
Here is mine, just had it done a couple days ago, those aren't real cats but look real enough...sounds awesome!!!!
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
01-01-2013, 01:28 PM | #8 |
01-01-2013, 01:31 PM | #9 |
It would only let me do one pic at a time,sorry
01-01-2013, 01:32 PM | #10 |
Another one
