Old 12-31-2012, 02:20 PM   #1
ScottG
Eaton HO52 rear end w/ trailing arms!!!
sold locally
I've got an Eaton HO52 rear end with 3/4 ton long bed trailing arms. Rear end is complete, drum to drum, with 4.10 gears open. With e-brake cables, ready to bolt in. sold pick up only!!! I'll throw in the drive shaft, for th400.
3rd member
'67 C20 LBW
ScottG is offline   Reply With Quote
Old 01-02-2013, 07:37 PM   #2
ScottG
Re: Eaton HO52 rear end w/ trailing arms!!!
ttt
'67 C20 LBW
Old 01-08-2013, 02:11 PM   #3
ScottG
If someone just needs the 3rd member, they can pick it up for 75.00 bucks!!
'67 C20 LBW
Old 01-08-2013, 06:32 PM   #4
capev86
did the truck have a dually conversion? i don't recognize those spacers outboard of the brake drums. be a slick way to increase the rear track width on my 72 Burb C20 which is kinda narrow imo.
capev86 is offline   Reply With Quote
Old 01-08-2013, 07:11 PM   #5
ScottG
Nope, that's the way I ran it on my truck, or I should say that's the way it came when I bought it. Wheels lined up fine, front and rear.
'67 C20 LBW
Old 01-08-2013, 07:25 PM   #6
ScottG
I don't know enough about these to give an accurate answer. thinking about it for a minute, it does look different than the rear end I took this 3rd member from, but I can't recall for sure.
'67 C20 LBW
Old 01-08-2013, 07:26 PM   #7
capev86
hmmm...maybe someone will clue me in to what those are and what they are doing on a 3/4 ton axle with coils/trailing arms.
Old 01-08-2013, 08:31 PM   #8
Marcello D'Ottavio
Would you sell the trailing arms?
Marcello D'Ottavio is offline   Reply With Quote
Old 01-09-2013, 11:42 AM   #9
ScottG
I will, but I don't know about shipping them to Canada. Could be very costly.
'67 C20 LBW
Old 01-09-2013, 02:20 PM   #10
Belairboy55
Active Member
I have the exact same rear end in a 71 C 20 and the pieces that look to be spacers are GM stock and are made to the drum. As ScottG stated the wheels fit as they should. No extra rear width. I always thought 3/4 ton trucks were leaf sprung but as I have purchased a few C 20 trucks I have seen more of them coil sprung.
Belairboy55 is offline   Reply With Quote
Old 01-31-2013, 02:49 PM   #11
ScottG
$150.00!!! for the rear end, trailing arms, and I'll even throw in the drive shaft!!! Come and get it!!
'67 C20 LBW
Old 02-03-2013, 10:56 PM   #12
A5window
Will you ship the 3rd member and hubs? I am too far away to pickup.
Mark
Lakeside MT
A5window is offline   Reply With Quote
Old 02-03-2013, 11:28 PM   #13
ScottG
Mark
Lakeside MT
I can. It's roughly 130 pounds or so, so it will be costly to ship. By the hubs do you mean the part pressed into the drums?
'67 C20 LBW
Old 02-04-2013, 12:41 AM   #14
A5window
I do, although I don't need the drums, just the srw hubs & bearings.
The best way to ship is probably Greyhound to Kalispell, MT.
My email is msletto@crowleyfleck.com
Old 02-05-2013, 08:30 PM   #15
tow guys
tow guys's Avatar
I would be interested in the center section shipped to zip 08721 if it gets to me.
thanks,
Tony
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431
Member of the 1-Ton Club!
http://www.eastcoastcarandtruck.org
tow guys is offline   Reply With Quote
Old 02-06-2013, 07:21 PM   #16
ScottG
gonna get it apart tomorrow. Too heavy for Greyhound. (135 lbs!) Maybe Ups.
'67 C20 LBW
Old 02-10-2013, 06:05 PM   #17
ScottG
sold locally.
'67 C20 LBW
4.10, eaton, ho52, trailing arms
