01-07-2013, 05:55 PM | #1 |
Carpe manana
Anyone rebuilt an OEM sliding rear window?
Need some direction as to how to and where to go for parts to rebuild a factory sliding rear window. I'll need the weather stripping and rubber pieces that were installed in the corners. Appreciate any help. Thanks.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
01-07-2013, 07:34 PM | #2 |
Re: Anyone rebuilt an OEM sliding rear window?
Pete, I'm no help but interested also for same answers. Have a factory slider in a '70 I'm slowly parting and it has some same issues sos wanna' subscribe on this.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
01-07-2013, 07:35 PM | #3 |
Also interested!
01-07-2013, 07:46 PM | #4 |
Has anyone called there local glass shop to see if they can get the stripping ? Just an idea it may be worth it
01-07-2013, 08:04 PM | #5 |
Carpe manana
Welcome aboard! The weatherstripping can be had I suspect. Here's a possible source though I have yet to check actual measurements:
http://afproducts.automotivefairchil...-run-channels? I need to track down the rubber "sweeps" that have a "T" shaped part which slides into a channel on the screw-affixed vertical metal "posts" and an "O" shaped part that provides the seal between the mobile glass pane and the fixed glass pane. I guess pics would help!
01-07-2013, 08:08 PM | #6 |
I didnt know they were an option. I assume i just look at the spid?
01-07-2013, 08:41 PM | #7 |
Carpe manana
rmmurphy - GM did offer a rear sliding window and trucks so equipped had the option listed on the SPID (A28)
Here's a pic posted by 1969 GMC:
01-07-2013, 09:02 PM | #8 |
Carpe manana
I tried a local glass shop (two) and called a local business that installs camper shells and repairs the sliders in these shells with no luck.
First image shows the "sweep" I need to track down: The sweep inserts into the vertical metal post at the far right of the second image. This post has screws (shown) that attach to the outer frame. The weather stripping and a plastic insert that goes into the bottom of the outer, narrow "C" channel are also shown: Third pic shows square rubber strips mounted inside the larger inner "C" channel at each corner that function as bumpers to stop the mobile glass. Mine are still surprisingly pliable and don't need to be replaced: Potential source for a replacement latch: http://www.technologylk.com/__663/cr...t-latches.html
01-07-2013, 09:14 PM | #9 |
i just checked my spid. mines not factory oh well i like it anyway
01-08-2013, 06:13 PM | #10 |
Carpe manana
Here's a shot of the screws on the lower corners that secure the frame pieces together and example etching on the glass of a factory rear slider:
01-09-2013, 12:29 AM | #11 |
I did not know that. So maybe the sliding window I'm selling is factory? It had a topper on it and I just don't remember the SPID.
01-09-2013, 12:31 AM | #12 |
I believe my Grandfathers old truck had that, not sure though
1971 GMC Sierra 1959 GMC 100 |
01-09-2013, 12:37 AM | #13 |
Why not buy an entire rear sliding window at the junk yard off one of our trucks? I just saw one a couple weeks ago at my local yard. I think it was a 71 gmc
Posted via Mobile Device |
01-09-2013, 12:38 AM | #14 |
Yeah that would be easier
01-09-2013, 09:20 AM | #15 |
Active Member
Glass on these trucks is an expendable part like a starter, alternator, tires, etc. Won't add or subtract much to the value unless it was a pristine original. I would just fine a good used one or even a new one.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
01-09-2013, 09:48 AM | #16 |
Subscribed, as I need to do this too. Here's hoping someone can track down a source for the weatherstripping.
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
01-09-2013, 11:22 AM | #17 |
I bought the lower seal from my local Glass Shop. I took the old one down and showed them what I needed and they came up with something very close. The seal was $4/foot.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-09-2013, 05:48 PM | #18 |
Carpe manana
Thanks Jim. I'll try another local glass place. This is an easily rebuildable part (vent windows more of a challenge) if I can track down the "sweeps". In the end I should have a nice tight OEM slider - will buff up the aluminum frame and should look good in my K20 resto.
01-09-2013, 05:56 PM | #19 |
Where they Custom to the trucks ?
01-09-2013, 06:04 PM | #20 |
Carpe manana
Available as a factory installed option (will be on SPID then like my K20) or probably a dealer accessory. With a few exceptions (like adding a 700r4 tranny, bucket seats) I'm trying to keep my build original and use OEM or NOS parts whenever possible. For me, a new slider won't cut it if I can refurbish an original piece and I'm skeptical that a 40 year old rear slider with tight seals and intact glass can be located in a salvage yard anywhere.
01-09-2013, 06:16 PM | #21 |
Makes me wonder if my Grandfathers had it, I cant recall it having one though
Hmmm
02-07-2013, 01:02 PM | #22 |
Did you ever find the seals for the slider?
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985 "The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945 |
02-07-2013, 04:35 PM | #23 |
The lock on mine is gone, sure would like to find a new clip, or even a new frame if that is what I need.
subscribed! Jeff
St. Louis, Mo 1969 C10 2011 Dodge Charger R/T (custom) |
02-07-2013, 08:38 PM | #24 |
Carpe manana
Slow progress but glad you checked in. Here's what I have so far. The grey sweep is OEM. The others I got from the scrap pile of a local glass shop (black - for screen door) or found online (white - from here: http://www.ultrafabsp.com/extruded_products/t-slot.php). The black sweep will hold snug in the T-channel and is in good shape so I'll prob use this one. The base of the "T" on the white sweep is just slightly too wide for the channel and needs a slight shave to fit, but with some small effort could be made to work. It's possible the company may have one that fits perfect, if/when I have time I may consider calling a salesman and sending and/or sending them a sample to match. I'm waiting to have the metal polished before reassembly.
02-07-2013, 08:40 PM | #25 |
Carpe manana
Another local glass wholesaler gave me a length of weatherstrip that's not a perfect match but should should work fine with a bit of Super 77 or other adhesive to keep it snug.
