Old 01-14-2013, 11:58 PM   #1
1979bonanza
Smoother ride
Looking to get a smoother ride out of my 1979 3/4 ton 4wd bonanza, any thoughts?
1979bonanza is offline   Reply With Quote
Old 01-15-2013, 04:00 AM   #2
65c10restomod
Re: Smoother ride
all season tires the more sidewall the better ,new standard shocks and springs ,new rubber bushings and mounts not poly,new seat.
65c10restomod is offline   Reply With Quote
Old 01-15-2013, 04:06 AM   #3
andrewmp6
Re: Smoother ride
Good shocks and tires can help to a point,But its a 4x4 pickup they will always ride rougher then a car does.
andrewmp6 is offline   Reply With Quote
Old 01-15-2013, 11:38 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Smoother ride
Welcome to the forum 1979bonanza. If your still running stock suspension, there not much that you can do. As mentioned tires and shock can help a lot. Look for a softer radial tire with a good quality shock.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-15-2013, 12:27 PM   #5
1979bonanza
Re: Smoother ride
thanks guys i didn't think there would be a whole lot i could do about it riding like a tank but the old shocks definitely need replaced and it wouldn't hurt to get some better tires. thanks again!
Old 01-16-2013, 05:11 AM   #6
andrewmp6
Re: Smoother ride
Get under it and look around see if you have any wore out parts too.
Old 01-16-2013, 11:58 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Smoother ride
You might consider a small lift kit. The factory springs are fairly flat and don't offer a lot of flex. The aftermarket springs give you more travel and offer a progressive rate.
Articles-
"Refining Sierra"
suspension
