Old 01-20-2013, 01:22 PM   #1
wsurf4me
wsurf4me's Avatar
Tilt wheel ignition problems
My sons 84 C10 wouldn't start yesterday. After a little troubleshooting we found that the starter is fine and it's the tilt column. If you push the tilt all the way down the starter turns over and it starts right up, any other tilt position and the starter does nothing. I've done some searching online without much success on this problem, anyone here seen this before? At this point I'm not sure how the ignition switch integrates with the tilt, is it mechanical or do I just have a loose electrical connection and tilting all the way down makes the connection? Any insight would be most welcome - thanks in advance.
wsurf4me is offline   Reply With Quote
Old 01-20-2013, 02:05 PM   #2
wsurf4me
wsurf4me's Avatar
Re: Tilt wheel ignition problems
So after some more searching I've found this -
http://imageshack.us/a/img370/6760/actuatorrackkv3.jpg
Think the actuator rod or rack could be messed up?
Old 01-20-2013, 02:13 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
yes also the ignition switch on the column base could be worn
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-20-2013, 03:08 PM   #4
wsurf4me
wsurf4me's Avatar
Well it just got worse, looks like something let go the key now turns freely and doesn't actuate anything. Also can't move it out of park, I assume something with the key switch assembly broke, anyone have a link to more info? exploded diagram?
Old 01-20-2013, 03:31 PM   #5
zirk
zirk's Avatar
Mine does a similar thing. Whenever completely up it doesn't start, but any other position and it works, I just kind of use it as theft proof
Chevy runs in my blood
zirk is offline   Reply With Quote
Old 01-20-2013, 05:59 PM   #6
wsurf4me
wsurf4me's Avatar
I've figured out that I can start it by moving the ignition actuator rod with a pair of pliers. The key still locks the steering wheel but nothing else, so between the two I can still start and drive it. I'm trying to find details on how the actuator rod connects to the key switch but haven't had any luck. Can anyone provide details?
Old 01-22-2013, 11:36 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
where the cylinder sits in, has a bit of gear teeth
they run back and forth on a small bit of gears that sits in the coloum
i'd bet one of those gears is gone
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-23-2013, 07:34 PM   #8
wsurf4me
wsurf4me's Avatar
That's exactly what happened, $10 part, 2 hours labor.
Old 01-24-2013, 11:28 AM   #9
D13
D13's Avatar
Where did you get the part? it's tim to perform that bit of surgury on mine...
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 07-06-2018, 02:12 AM   #10
GSP7
GSP7's Avatar
What happened with this thread ? I need some help .
Go here
http://67-72chevytrucks.com/vboard/s...d.php?t=766925
This is a 81 K20 silverado and a tilt column
I found this picture . I did not put that red arrow but seems maybe something around there broke?
P.S. Matter a fact shining a flashlight into the tilt part of my column, I can ses loose broke piece. I thing that part at the red arrow broke , a piece is broke off , maybe that loop part?
Can I get these parts anywhere?
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 07-06-2018, 06:55 AM   #11
70GMCer
70GMCer's Avatar
https://www.amazon.com/gp/product/B0...=ADKKWWSNTS2OR
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
ignition, tilt
