Old 01-23-2013, 01:13 PM   #1
AirSpeed
AirSpeed's Avatar
Anodizing aluminum
I've been anodizing stuff on and off for a few years and started doing it a little more seriously now, I used to do it with my batt charger but it was to inconsitant so I bought a new constant current power supply. What a difference, here's some parts I just finished, they motorcycle parts for a friend.
[IMG][/IMG]
AirSpeed is offline   Reply With Quote
Old 01-23-2013, 01:52 PM   #2
flashed
Re: Anodizing aluminum
Looks great .
flashed is offline   Reply With Quote
Old 01-23-2013, 04:41 PM   #3
LEEVON
LEEVON's Avatar
Wow, that's cool. I didn't know that was a DIY possibility. Can you share about the process?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-23-2013, 06:14 PM   #4
AirSpeed
AirSpeed's Avatar
Thanks! It's a fairly simple process but a LOT can go wrong, most everything you need to do basic anodizing can be found easy enough, a power supply, sulphuric acid (battery acid) plastic tanks for to ano in, sheet aluminum for the cathodes, you can even use Rit dye as long as your part isn't in the sun a lot. I used a regular battery charger for a long time with pretty good results but I recently bought a constant current power supply to get more consitant results. Go to the website forum at Caswells, it will explain the process better than I can. It's easy to do once you understand the process, I was able to figure it out and had good results the first time I tried it. It took me a few tries to learn the system Caswell teaches, it's called LCD and you need to either build a circuit to monitor and control the amperage or pick up a constant current power supply. I picked one up at Amazon for $130, well worth the price for the results I'm getting now. Check out Caswells website and forum, it seems a little intimidating at first but once you start building your system and get it running its pretty easy. Thanks again!
Old 02-22-2013, 04:29 PM   #5
AirSpeed
AirSpeed's Avatar
I did a few more parts yesterday, these are for a couple of stree bikes, I have no idea where they go though!
These are raw, the one on the right is polished.
Here they are after anodizing and dying
Old 02-22-2013, 04:52 PM   #6
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Would you be interested in doing some parts for me? You're doing a great job!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-22-2013, 05:20 PM   #7
AirSpeed
AirSpeed's Avatar
What do you have?
Old 02-22-2013, 06:01 PM   #8
Dieselwrencher
Originally Posted by AirSpeed View Post
What do you have?
Some valve covers, maybe a turbo compressor cover. I can get you pics of the pieces.
Ryan
Old 02-22-2013, 06:14 PM   #9
AirSpeed
AirSpeed's Avatar
It's not easy anodizing cast aluminum depending on how they are cast and the alloy. If they are die cast they will have a lot of copper in the surface which won't grow the ano layer. If they're milled I should be able to do it. I rently tried some cast aluminum peg mounts on a Honda street bike that wouldn't take at all. Is the turbo housing polished? Can you tell if its sand or die cast?
Old 02-22-2013, 09:27 PM   #10
Dieselwrencher
All these pieces I have besides the valve covers are cast and have a rough surface. So I'm guessing sand. IDK for sure.
Ryan
Old 02-23-2013, 12:44 PM   #11
AirSpeed
AirSpeed's Avatar
I probably wouldn't want to ano those parts not knowing what alloy and casting was used, I've anodized parts I've cast myself but I knew the alloy. Milled parts are easy but cast parts are unpredictable and I couldn't gaurantee how well or even if they could be done.
