Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-25-2013, 11:51 AM   #1
blazer2007
oops,put a hole in speaker
I put a L shaped hole in the foam on a sub with my cordless screwdriver installing it.Any ideas on fixing it ,some sorta glue or fabric tape
blazer2007 is offline   Reply With Quote
Old 01-25-2013, 12:23 PM   #2
64fleetside
Re: oops,put a hole in speaker
I've used contact adhesive and a patch from a coffee filter.
64fleetside is offline   Reply With Quote
Old 01-25-2013, 12:29 PM   #3
fattyarbuckle
if it's a good speaker you can replace the foam pretty easy.
I just repaired mine recently and it worked good.
http://www.speakerworks.com/speaker_..._kits_s/65.htm
be sure to center the cone and all is good.
fattyarbuckle is offline   Reply With Quote
Old 01-31-2013, 11:54 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
if you use glue, be sure to trim the excess it will flutter
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-06-2013, 08:02 PM   #5
76stepsidechevy
Whats the surround made of ? foam, butyl rubber, ect.
76stepsidechevy is offline   Reply With Quote
Old 02-10-2013, 04:06 PM   #6
68Timber
I know the pieces fit
68Timber's Avatar
Dab of RTV will do it.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
