Old 01-29-2013, 02:18 PM   #1
blackbeaSSt
02 burb low coolant light on
but this is the level its at when the engine is cool. that seems very minor for the light to kick on. or does that seem about right?
blackbeaSSt is offline   Reply With Quote
Old 01-29-2013, 08:27 PM   #2
gmclowsierra
Re: 02 burb low coolant light on
Your sensor in the tank is going bad.
gmclowsierra is offline   Reply With Quote
Old 01-29-2013, 08:38 PM   #3
blackbeaSSt
is that the blue and white piece on the bottom right of the tank in that pic?
Old 01-29-2013, 08:44 PM   #4
gmclowsierra
Thats the plug yes. Yes you will need to change out the overflow jug to change the sensor.
Old 01-29-2013, 11:26 PM   #5
LT1 Burb
LT1 Burb's Avatar
My 01 Yukon used to do that all the time and for some reason it would just eat coolant. I probably added 2 gallons over 80k miles and it just quit doing it. Sometimes the level was fine and the coolant light would go on but it just quit doing it.
LT1 Burb is offline   Reply With Quote
Old 01-30-2013, 12:51 AM   #6
Easyeight
Be wary if your late 1990's/early 2000's GM truck engines are 'disappearing' coolant!
Intake manifold gaskets on 4.3 V6 on up(5.7 and 5.3 engines too) are notorious for leaking intake manifold gaskets. Coolant can either burn in the cylinders..or leak into the oil..or both.
My wife's 2003 Tahoe has a bogus coolant level sensor...has had for years. I just open the hood about one a week to be sure everythings full.
Easyeight is offline   Reply With Quote
Old 01-30-2013, 10:32 AM   #7
blackbeaSSt
would that make a sort of flapping/ticking sound while idle and driving?
Old 01-30-2013, 10:33 AM   #8
blackbeaSSt
ohhhhh, so the sensor is literally in the tank? and the whole tank need to be replaced?
Old 01-30-2013, 10:44 AM   #9
Easyeight
Hmmm..that sounds like normal fuel injector noise or possibly lifters clattering.
Now lifters sticking and clattering could be a symptom of coolant in the oil..is the oil just really brown looking when you change it??
I had a 97 GMC that was losing small amounts of coolant..and it's oil was nasty-brown at oil changes. Replacing the intake gaskets fixed that. It would have lifter issues sometimes.
A 97 Z71 with a 5.7 had bad intake gaskets..and started gushing coolant externaly at the rear of the head one day!
My wifes 2003 Tahoe developed an issue where it would just up and die at idle(like at a stoplight)...this was a 5.3 engine..and it turned out to be intake manifold gaskets too...not leaking/losing coolant but a vacum leak.
Old 01-30-2013, 09:33 PM   #10
gmclowsierra
The new ls engines do not have coolant in the intake. 4.8 5.3 6.0 only have coolant in the throttle body.
Old 02-07-2013, 01:32 PM   #11
69gmcc10
69gmcc10's Avatar
On an ls engine it is common for the gaskets between the block and the water pump to develop a good leak and not see it pool under the truck, the coolant will evaporate from the heat of the engine before it can drip off. if you slide under the truck and look at the gaskets you can often see a tarnish like staining on the block, gasket, water pump or all 3. This may not be the answer to missing coolant, but it is allot cheaper and easier than a head gasket and worth a check to save some $$$.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 02-07-2013, 02:17 PM   #12
blackbeaSSt
lemme ask you guys this, is it normal for the low coolant light to come and go, or just pop up every time i start the truck?
i haven't seen it but once more after i made this thread.
Old 02-07-2013, 02:44 PM   #13
69gmcc10
69gmcc10's Avatar
I have herd that the sensor going bad is common and you need to replace the tank with the sensor in it, but I dont know what the symptoms are that make it a "bad" sensor. If it were me I would check the connection and just keep an eye on the coolant level until the light started bothering me.
Old 03-01-2013, 04:28 PM   #14
blackbeaSSt
ding ding ding! we have a winner!
didn't think anything else about the leak since i made this thread until last night when i found a puddle in the carport. i could tell it was dexcool but couldn't tell where it was coming from. needless to say i now have a new water pump/rad. hoses/and thermo on black beauty
Old 03-01-2013, 05:57 PM   #15
69gmcc10
69gmcc10's Avatar
glad you got it squared away!
