01-31-2013, 10:57 PM | #1 |
Any Pictures of how rear swaybar mounted?
I have trailing arm rear....would love to see pictures of how you mounted your rear sway bar........
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
02-01-2013, 02:17 PM | #2 |
Re: Any Pictures of how rear swaybar mounted?
I'd like to see this too.
02-01-2013, 02:55 PM | #3 |
Old member
Well it depends on which one you buy as to how it mounts. The aftermarket ones mainly mount to the frame and arms.
The camaro ones mount to the frame and rear axle as I did mine. This is mine it's the camaro bar. Bought it out of the junkyard. Painted it: Spacers I made for the frame: Kit for Installing it: Here is the thread on my install. http://67-72chevytrucks.com/vboard/s...d.php?t=305902
02-01-2013, 05:41 PM | #4 |
Ah, point it backwards.... Why didn't I think of that?
02-01-2013, 05:43 PM | #5 |
I think I have a rear bar off of a 90's tahoe sitting around somewhere, wonder if that will fit this way.
02-01-2013, 06:11 PM | #6 |
but....but....but I have leaf springs.....Will it, can I, I need to...........
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
02-01-2013, 06:15 PM | #7 |
THIS is also my question.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
02-01-2013, 06:21 PM | #8 |
what year camaro?
02-01-2013, 07:00 PM | #9 | |
i bought the sway bars from CPP, but i don't like the setup for rear bar for the trailing arm setup. i was thinking of adapting the CPP rear bar for a leaf spring truck. as long as it clears the 3/4 ton Corp/Eaton diff and track bar mount, it should give better ground clearance. and unlike with the camaro bar, the ends will line up with the truck frame (no spacers needed). also, the CPP rear bar is 1-1/8" dia which i think is a good idea on a suburban. |
02-01-2013, 07:34 PM | #10 |
70+ ( Old Skool Club )
Subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-01-2013, 08:03 PM | #11 |
Old member
I can't say 100% if it will work but I see no reason it shouldn't though.
