Old 02-02-2013, 05:58 PM   #1
ronmonteith
Installing a Rebel wiring harness
I have a 71 C10 short bed truck. I am replacing the old wiring with a Rebel Harness. This kit was $169.00 which was cheap but I am having to put the connectors on myself which is fine. The challenge I am having is in the steering column and the instrument cluster. The old wiring does not match up to the new wiring and I am not sure which color wire goes where?
ronmonteith is offline   Reply With Quote
Old 05-02-2013, 12:26 PM   #2
Fattback
Fattback's Avatar
Re: Installing a Rebel wiring harness
Starting to look into getting a wire harness. Did you figure out the steering column and cluster issue? Would you recommend Rebel Harness?
Rob
Fattback is offline   Reply With Quote
new wire, rebel wiring, wiring
